Author Topic: K7203 with 60-in-1 Screen issue  (Read 1196 times)
pincoma
  • Last login:July 26, 2015, 10:12:37 pm
« on: June 14, 2015, 02:13:08 pm »
I have a K7203 that I'm hooking up a 60-in-1 to.
I have my red, green and blue connected properly according to the manual.
The jamma harness only has "sync" wire coming out of it.  I have this on the H/VCOMP which is pin 6.
I get the screen with correct colors, but the image repeats itself across the screen and seems to be scrolling [from long side to long side].
How to fix?
Do I need to have this wire loop to pin 10 also which is -H/VCOMP?
I'm a pinball guy dabbling in the video world so any help is much appreciated.
pincoma
Re: K7203 with 60-in-1 Screen issue
« Reply #1 on: June 14, 2015, 02:20:14 pm »
Does it require video ground to the jamma harness?
my harness didn't have that wire preinstalled.
grantspain
« Reply #2 on: June 14, 2015, 04:18:35 pm »
you need to connect jamma sync  to the negative h sync pin on the chassis
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #3 on: June 14, 2015, 05:23:44 pm »
dip switch 2 sets the sync freq .
"off" for standard resolution (15.734khz)
"on" for use with vga monitors , etc
note: pwr down before changing setting
have done several of these conversions for a route operator ...........
