Author Topic: HLSL advice and help needed  (Read 2768 times)
UKDAVE1979
  • Last login:June 01, 2015, 10:03:15 pm
« on: June 01, 2015, 08:19:18 pm »
Hello,
I was hoping a few of the people in the know can help me out with this..
Mame 1.55 running great on the new cabinet, I'v lately came across some posts across the net in regards to the HLSL settings that can be tweaked to emulate a CRT.
Can anyone explain what is needed to do so? I have tried setting the 0 to 1 but soon as I fire up mame all games crashes on start-up. I get a windows pop up saying "Mame has stopped responding". if I change the setting back to 0 it is fine again, no problems loading games.
I'v also went into the Mame system options and ticked the HLSL setting to on but the same results.
Am i missing something? I can use the built in settings withing Mame and these work fine to emulate scanlines, Hantarex, Triad etc..
Can anyone see the problem?
The GPU im running is the 2g GTX 750 TI if this info is needed
Thanks,
Dave.
B2K24
  • Last login:June 10, 2025, 10:17:56 am
Re: HLSL advice and help needed
« Reply #1 on: June 01, 2015, 09:12:52 pm »
So much has changed since 0.155 that you need to upgrade to the latest version (0.162) to fully take advantage of the latest changes and fixes.
https://github.com/ImJezze/mame/commit/a70198a5fb532f1b5826bcc0a318c1d68291c0c4
If you're willing to upgrade, make a fresh mame.ini and then you can use these settings as a base which you can tweak if you want.
Code: [Select]
hlsl_enable               1
hlslpath                  hlsl
hlsl_prescale_x           8
hlsl_prescale_y           8
hlsl_preset               -1
hlsl_write
hlsl_snap_width           3200
hlsl_snap_height          1800
shadow_mask_alpha         0.5
shadow_mask_x_count       6
shadow_mask_y_count       4
shadow_mask_usize         0.1875
shadow_mask_vsize         0.25
shadow_mask_uoffset       0.0
shadow_mask_voffset       0.0
curvature                 0.0
round_corner              0.0
reflection                0.25
vignetting                0.25
scanline_alpha            0.75
scanline_size             1.0
scanline_height           1.0
scanline_bright_scale     2.0
scanline_bright_offset    0.0
scanline_jitter           0.0
defocus                   1.0,0.0
converge_x                0.0,0.0,0.0
converge_y                0.0,0.0,0.0
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.05,0.00,0.10
grn_ratio                 -0.10,1.00,0.25
blu_ratio                 -0.25,0.25,1.25
saturation                1.25
offset                    -0.30,-0.20,-0.05
scale                     1.15,1.05,0.90
power                     0.90,0.90,1.15
floor                     0.05,0.05,0.05
phosphor_life             0.5,0.5,0.5
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_cc                    3.59754545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     1.570796325
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_length_scale       0.8
vector_length_ratio       40.0
# BLOOM POST-PROCESSING OPTIONS
vector_bloom_scale        1.00
raster_bloom_scale        0.220
bloom_lvl0_weight         1.00
bloom_lvl1_weight         0.16
bloom_lvl2_weight         0.24
bloom_lvl3_weight         0.32
bloom_lvl4_weight         0.48
bloom_lvl5_weight         0.00
bloom_lvl6_weight         0.96
bloom_lvl7_weight         0.72
bloom_lvl8_weight         0.48
bloom_lvl9_weight         0.24
bloom_lvl10_weight        0.12
UKDAVE1979
« Reply #2 on: June 01, 2015, 09:36:22 pm »
Thanks for the reply, unfortunately I wouldn't know how to upgrade to a different version, I'm a novice at all this.
I had the cabinet built with Mame pre-installed.
I'm just stuck as to how to get around this problem.
Out of curiosty what major changes were there with that version of Mame?
Thanks,
dave.
lamprey
« Reply #3 on: June 02, 2015, 11:39:12 am »
Are you using some mame with a UI? If so, do you know which variant? "Mainline" MAME doesn't have UI per se, just a very basic UI.
Also, was HLSL ever working on your system? Hard to say from your error message, but maybe you need to install the DirectX 9 runtime..?
Here is a link about some of the changes in 0.162. But, from 0.155 to 0.162 there are TONS of changes:
http://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=340496&page=0&view=collapsed&sb=5&o=&fpart=1&vc=1&new=1432834325
lettuce
  • Make It So!
« Reply #4 on: June 02, 2015, 12:49:33 pm »
Code: [Select]
hlsl_enable               1
hlslpath                  hlsl
hlsl_prescale_x           8
hlsl_prescale_y           8
hlsl_preset               -1
hlsl_write
curvature                 0.0
round_corner              0.0
reflection                0.25
vignetting                0.25
scanline_alpha            0.75
scanline_size             1.0
scanline_height           1.0
scanline_jitter           0.0
defocus                   1.0,0.0
saturation                1.25
yiq_enable                0
yiq_cc                    3.59754545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     1.570796325
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
Damn prescale at x8!!!, doesnt that seriously effect performance or has HLSL been super optimised over the last few releases!!?
lamprey
« Reply #5 on: June 02, 2015, 12:58:08 pm »
I can/does. But, with a "modern" video card you wouldn't notice as much. I haven't messed with the new HLSL changes (0.162) yet, but setting prescale to 0 in the past was, generally, the best option. But, everyone's situation is different.
B2K24
« Reply #6 on: June 02, 2015, 01:33:11 pm »
I got a Nvidia GTX 760 and most everything I've tried runs 100% with the exception of TG16 and PCECD
lettuce
  • Make It So!
« Reply #7 on: June 02, 2015, 02:06:02 pm »
I was under the understanding that you had to change the prescale option under the 'OSD ACCELERATED VIDEO OPTIONS' to get it prescale to work, initially i though setting prescale to '0' was to disabled and the '1' was to enable it and then you just changed it to what you wanted in the HLSL section but that doesn't appear to be the case, you have to set the prescale option in the 'OSD ACCELERATED VIDEO OPTIONS' section to what you want for example '4' or '6' so what does the prescale option in the HLSL section actually do?
« Last Edit: June 02, 2015, 02:11:07 pm by lettuce »
lamprey
« Reply #8 on: June 02, 2015, 02:15:44 pm »
A prescale value of 0 (zero) is Auto, not disabled.
I don't know if the latest round of changes has an affect on prescale, but here is a link to an discuss about it on the previous incarnation (with pics):
http://shmups.system11.org/viewtopic.php?f=6&t=45026&sid=07670e044cda650e6881d254ff050991&start=360
EDIT: I see some potential for confusion. When I said "prescale" I was talking about the hlsl_prescale_x & hlsl_prescale_y values.
« Last Edit: June 02, 2015, 04:21:53 pm by lamprey »
