Author Topic: Horizontal Green line, nothing else  (Read 1380 times)
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
« on: May 13, 2015, 10:17:16 am »
I've got an arcade monitor (unknown monitor at this time) that displays a bright neon green line across the center.
I know its not much info, but I havent had a chance to dig into it.
Cap kit? Flyback? Other?
grantspain
Re: Horizontal Green line, nothing else
« Reply #1 on: May 13, 2015, 10:55:49 am »
depends on if its vertical or horizontal collapse
Sarver Systems
« Reply #2 on: May 13, 2015, 12:00:13 pm »
Its a shooting game, so the monitor would be mounted horizontal.
grantspain
« Reply #3 on: May 13, 2015, 04:31:13 pm »
vertical collapse
what make/model?
Sarver Systems
« Reply #4 on: May 14, 2015, 02:47:53 pm »
Its a Wells Gardner, 25" or 27" flavor.
grantspain
« Reply #5 on: May 14, 2015, 04:41:52 pm »
info is a bit thin,likely to be vertical deflection ic or the vcc to said ic
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #6 on: May 14, 2015, 09:59:05 pm »
don't forget to check the retrace cap, and/or degraded solder on the IC   likely a TDA1771
cap is typ 100-330uF/35-50 volt
