Author Topic: Mame4all front end  (Read 5092 times)
Binkles
  • Last login:May 05, 2017, 10:41:45 am
Mame4all front end
« on: May 10, 2015, 06:48:15 am »
Can anyone recommend a front end for mame4all?
I have rasping installed and only mame4all.
I use Mala on my upright windows machine, but want to put basic vertical menu for the cocktail.
Something like the *cough* 60in1 menu would be ideal.
I know mame4all has its own built in, but looking for something different, and graphical.
Sent from my iPad using Tapatalk
lostboy4480
  • Last login:January 29, 2026, 12:27:18 pm
Re: Mame4all front end
« Reply #1 on: May 10, 2015, 12:10:52 pm »
Have you tried Attract Mode Front End,  Here is an active post of the status of getting it working on the Pie
http://forum.attractmode.org/index.php?topic=107.15
Cabinets
NBA Jam
Golden Tee 2005
PGA Tour Golf Team Challenge
Tekken 5: Dark Resurrection
Generic Taito (Project)
Binkles
« Reply #2 on: May 10, 2015, 06:20:54 pm »
Thanks, looks more for the pi2 with its extra grunt.
nitrogen_widget
« Reply #3 on: May 10, 2015, 10:41:09 pm »
Actually i did the same thing on the RPI 1 with 256 mb for the heck of it and it works surprisingly well.
I used the diet_pi distro with its minimal x windows.
Plus rayman got hardware acceleration going on his feet on RPI.
The version of the os I originally used was beta according to the Dev.
I built a new one this weekend with the latest version of diet_pi that will run on either RPI 1 or 2 and I plan to share it as soon as I can.
It just takes a while to create an image that doesn't require the same size card I'm currently using (16gb) and up load it to drop box.
Which I'll do once I have it all set up and ready to go.
« Last Edit: May 10, 2015, 10:44:16 pm by nitrogen_widget »
Binkles
« Reply #4 on: May 11, 2015, 07:24:41 am »
I understood the first paragraph, then it went south from there ;)
Are you saying you would upload an image file to burn?
nitrogen_widget
« Reply #5 on: May 11, 2015, 12:30:23 pm »
I will upload  an RPI image that you can load onto an SD card & boot up your RPI with.
it would be just like putting rasbian or retro pi on an sd card.
Except, what I made is just a simple linux install with attractmode pre-compiled for you and the retropi install script already on it.
you will have to learn attract mode & retropi & figure out your own controller scheme though.
