Author Topic: Rowe R83 jukebox  (Read 2203 times)
rminnehan
  • Newbie
  • Last login:May 06, 2015, 04:41:32 pm
Rowe R83 jukebox
« on: April 28, 2015, 09:11:41 am »
I just got a Rowe R-83-A jukebox. It does all sorts of things or doesn't do anything at times. I am sure I will have to go through everything but I can't find any documentation on how things work as far as switches and everything goes. Does anyone have or know where I can get any operators manuals, service manuals, schematics, etc? Thanks, Roy Minnehan
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Rowe R83 jukebox
« Reply #1 on: April 30, 2015, 05:40:35 am »
Hello,
Dependant on which country you reside will dictate where to get a manual.
Once you have purchaced a manual (in the USA www.victoryglass.com may be your best bet)
I would suggest that you send the following boards to a specialist (there are only a few of us worldwide) for testing/repair:-
Memory Unit (located on the righthand side of the mechanism) 301-07855
Mechanism Control Unit (located on the lefthand side of the mechanism) 401-06905
Selector Logic (located on the righthand side of the cabinet) 601-08060
The Memory Unit & Selector Logic contain CMOS chips and are very proned to static dischange, so the boards need safe handling.
Once the boards are good you can then start on the mechanical adjustments that are fully featured in the manual, start at the begining and work your way through them, checking all the time for any wear in the parts. Replace these where necessary and only lubricate sparingly (only one drop of oil, more or less just the oil wicks on the motors, idler wheel linkage, idler weel shaft and turntable shaft ) where indicated.
Please let us know how you get on.
Regards
Alan
Alan Hood
ami-man
UK
