Author Topic: 19" Vision Pro LCD Monitor Suzo Happ - Screen out of position  (Read 1870 times)
mxwebman
  • Last login:September 22, 2015, 11:25:21 pm
Hi all,
I bough a 19" Vision Pro LCD Monitor from Suzo Happ to use on my arcade machine. I'm testing it now with my desktop, running Windows XP. What happens is that the screen is fine when I'm using normal Windows applications, but when I start any emulator like Mame, Atari, etc., the screen is not centered. It's moved to the right. If I use the monitor controls to make it back to the left, then the Windows is not centered anymore.
I need some advise before I start to try other things, like install Windows 7 or buy another video card.
Thanks.
grantspain
Re: 19" Vision Pro LCD Monitor Suzo Happ - Screen out of position
« Reply #1 on: April 27, 2015, 04:28:58 pm »
the auto adjust should lock it
mxwebman
« Reply #2 on: April 27, 2015, 04:31:35 pm »
I'm almost sure I tried it, but I will try again during the gameplay.
grantspain
« Reply #3 on: April 27, 2015, 06:14:49 pm »
yes try it when the picture is out of position,many lcd you have to lock to each resolution change
mxwebman
« Reply #4 on: April 27, 2015, 08:15:59 pm »
It worked!! Thanks a lot bro!! :)
