Author Topic: PacMAME w/ NoNag + HLSL?  (Read 2550 times)
newoski
  • Last login:February 26, 2021, 07:44:50 am
« on: April 26, 2015, 03:48:14 pm »
Hi Guys,
I'm currently using a really old version of PacMAME. I'd love to get this system setup using a newer emulator with nonag and HLSL support.
Is there anything out there that is compatible these days? Or is it possible to compile nonag / HLSL using the old source code?
« Last Edit: April 26, 2015, 03:49:52 pm by newoski »
bulbousbeard
  • Last login:August 25, 2015, 11:58:25 pm
Re: PacMAME w/ NoNag + HLSL?
« Reply #1 on: April 26, 2015, 04:54:53 pm »
You don't want to use HLSL anymore. You want to use OpenGL with Timothy Lottes's GLSL shader. It looks way better.
Also, PacMAME is done. You just want a standard MAME + HBMAME for the hacks.
If you go on the MAME site and follow the instructions, you can learn how to compile your own build. A simple Google search will give you the information you need to remove the nag screens.
newoski
« Reply #2 on: April 26, 2015, 05:03:01 pm »
Thanks. I know how to compile, my question is simply... what should I compile that would be compatible with games like abortman etc... The lesser known Pacman variants. These don't seem to be supported by HBMAME 0.160 or MAME
