Author Topic: mp3 volume  (Read 4283 times)
jim26
  • Last login:December 27, 2003, 05:42:39 am
mp3 volume
« on: December 27, 2003, 05:45:27 am »
hello all
a quick question: when playing a list mp3 files in realplayer they play at different volumes. This is rather annoying. Is there a program that will automatically adjust the volume so that they all play at SAME loudness?
Many thanks
Generic Eric
Re:mp3 volume
« Reply #1 on: December 27, 2003, 06:18:31 am »
Winamp had a function, that I believe could do that.  I recall with winamp you could configure the equalizer based on the song that was being played, and save that setting.  With the amount of mp3s I have, that would be time consuming.  I would discourage you from any function that plays them all level, I don't think you will be happy.
Did you rip the songs yourself?  That is the best way to ensure that you are happy with the quality.  I have downloaded a lot of crap myself, so I ended up doing my own.
Good luck.  Post your results, we could all benefit from the knowledge.
jim26
Re:mp3 volume
« Reply #2 on: December 27, 2003, 02:51:38 pm »
visciouslymamed
  • Last login:December 02, 2011, 08:38:46 pm
Re:mp3 volume
« Reply #3 on: December 28, 2003, 03:39:40 am »
Oldskool
  • Last login:November 30, 2007, 06:45:38 pm
  • Puttin' on the foil.
Re:mp3 volume
« Reply #4 on: January 14, 2004, 07:39:16 am »
http://www.geocities.com/mp3gain
Have you tried this? I'm going to give it a go later.
I've never had luck with "automatic" normalizing programs....
%$#@!&* machine took my quarter!
ashardin
  • Last login:December 19, 2007, 07:43:09 pm
Re:mp3 volume
« Reply #5 on: January 14, 2004, 04:52:29 pm »
I've used MP3Gain and it worked very well for me.
YMMV though, but I like it.
Oldskool
Re:mp3 volume
« Reply #6 on: January 26, 2004, 12:13:50 pm »
It worked, it worked, it worked!!!!
As I mentioned before, I've used several WAV normalizing programs and all were a big disappointment when used in "automatic" mode.
MP3 Gain has made me a believer.....
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
Re:mp3 volume
« Reply #7 on: January 29, 2004, 10:27:18 am »
How does this mp3gain work? It claims to be lossless and not to decode-reencode.
Does it simply adjust  the volume tag in the ID3v2 tag or does it really scale the track?
If I get a chance I might try to run it on a file and see if it modifies the whole file or changes ID3tags.
While I'm at it: do you have a favorite ID3 ta viewer and editor?
Edit: I looked in more details at the MP3Gain web site and what it does is tag the MP3 with a "replay gain" value in the ID3v2 field, so it works only if your player understands how to use the tags. I have no idea if players usually do or not...
« Last Edit: January 29, 2004, 04:14:26 pm by papaschtroumpf »
A. Aylestock
  • Last login:July 21, 2004, 09:17:41 am
  • Author of PartyTime Jukebox
    • Home of PartyTime Jukebox
Re:mp3 volume
« Reply #8 on: February 05, 2004, 12:03:58 am »
MP3Gain  only stores the volume information in the mp3 tag in case you want to undo the gain change and revert back to the original file
snakepit
  • Last login:April 07, 2011, 01:45:01 pm
Re:mp3 volume
« Reply #9 on: March 02, 2004, 04:47:55 pm »
What Level are you setting your mp3's to?
locationnyc
  • Last login:July 18, 2004, 07:11:55 am
Re:mp3 volume
« Reply #10 on: July 17, 2004, 01:37:18 pm »
thank YOU!!!  damn, i been thinking about this for toooo long, this program rocks...really, thank you for taking the time
peace
http://www.experts-exchange.com/Miscellaneous/Q_20742899.html
A. Aylestock
Re:mp3 volume
« Reply #11 on: July 21, 2004, 09:57:05 am »
Using MP3Gain, I always set the target "normal" volume gain at 98 db rather than the 89 default.
NOTE: At this level you are likely to see some tracks appear with a "Y" in the clipping column.   ::)
HOWEVER
