Author Topic: Easiest way to enable your PC wheel to work with non supported games?  (Read 6369 times)
delt31
  • Last login:August 01, 2020, 03:11:10 pm
I would like to use my wheel on my dreamcast emulator, or other arcade emulators however often times it is not recognized. Using GT force logitech wheel.  Any suggestions on what you guys use to map this to work?  Is it possible?  Example - want to use the wheel with nulldc (for hydrothunder).
ark_ader
  • I glow in the dark.
Re: Easiest way to enable your PC wheel to work with non supported games?
« Reply #1 on: April 17, 2015, 11:36:27 pm »
Why not get a DC wheel and hook it up to the PC.  Plenty of them out there.  ;)
mimic
  • Last login:July 20, 2025, 09:41:28 am
« Reply #2 on: April 17, 2015, 11:44:10 pm »
Could Xpadder be the answer? With that program you can map any controller to keyboard. I'm not sure if there is a trial version on their website though. http://www.xpadder.com/
  • Last login:Today at 10:08:11 am
« Reply #3 on: April 19, 2015, 01:28:36 pm »
It is probably working sometimes and not others because you are unplugging it and the controller ID is changing.
The solution is to leave it plugged in.
Logitech wheels work fine for NullDC or any other program that accepts input from an analog direct input controller (i.e. any game controller made before xbox360 controllers became the standard for pc games).
If you want to remap buttons or have the buttons post as keyboard keys instead, use Logitech profiler software.
