Author Topic: A first build named Retroclash - DONE  (Read 15852 times)
Brouhaha
  • Last login:January 31, 2022, 01:05:15 pm
  • Learning as I go!
« on: April 07, 2015, 08:49:13 pm »
Hello everyone,
After lurking for a while now, the time has finally come for me to build my own arcade cabinet  :D The house renovations are all done and, more importantly, the basement room to accommodate it is ready!
The build started about a month ago. My wife is a designer crazy about vintage stuff so I had to go with something funky/retro to get spousal approval  ;) Here came ARTIFACT. Absolutely loved the curves on that one so I decided to give it a try. I am modifying it slightly since mine will accommodate a 20'' 4:3 LCD so it can be thinner. It also won't be as wide since I am doing without a trackball.
So here we go...
The initial panel, ready to be sanded and used as a template for the other side:
Clamped and used for the second panel:
Second panel cut roughly, ready to be routed:
Frame and wheels:
And it's up!
Few panels on and satisfied with my simple CP layout:
Speaker panel (grilles are going over):
Sexy curves I liked so much about ARTIFACT I can now touch:
Screen panel routed and installed:
This is pretty much where I'm at :) I will be updating slowly as I go along from now on...
And really, a big thank you to all of you for this awesome community! It really motivated me reading all of you!!! Here's to hoping the worst doesn't happen and this thing ends up looking half-decent  :cheers:
« Last Edit: December 12, 2015, 11:28:43 pm by Brouhaha »
keilmillerjr
  • Web Developer.
Re: A first build named Retroclash
« Reply #1 on: April 07, 2015, 09:13:46 pm »
It looks good! :cheers:
Brouhaha
  • Learning as I go!
« Reply #2 on: April 08, 2015, 07:05:01 am »
Thanks  :) So far, I'm doing better than I thought. I'm about to start the artwork for the Marquee and CP to order from gameongrafix.com while I prime and paint the cabinet...
From what I understand, the CP artwork is Polycarbonate Laminate. Sorry for the newb question, but can this bend? I want it to go down on the CP front panel too in one piece. Is that feasible? I'd like to do without vinyl and plexi over if possible.
  • Last login:Yesterday at 10:57:44 pm
« Reply #3 on: April 08, 2015, 11:33:12 am »
Are you going to cut a t-molding slot? If yes, you should do it now...
Brouhaha
  • Learning as I go!
« Reply #4 on: April 08, 2015, 02:41:06 pm »
Thanks for the head up Yotsuya! Yes I do plan to slot it for t-molding :) It's the absolute last thing I want to do before painting it. I figured it would make the corners weaker and I still have to move it around a bit (still missing a few holes in there).
Cheers!
RxBrad
  • Last login:May 31, 2023, 12:41:00 pm
  • I like burritos.
    • bit.ly/1GDVYUu
    • RxBrad.com
« Reply #5 on: April 08, 2015, 03:47:24 pm »
The Gallery link on GoG shows a few CPs where the overlay is installed around curved surfaces, so I'd think you're okay.
EDIT: Their FAQ also linked to this post telling how to install their CPO on curved surfaces...
« Last Edit: April 08, 2015, 04:00:56 pm by RxBrad »
Mamezilla
  • Last login:April 19, 2024, 09:19:21 am
« Reply #6 on: April 08, 2015, 07:00:20 pm »
Nice work !  Also nice to see someone else from Quebec city in here !
Don't throw rocks to a man with a machine gun
-- Rowdy Roddy Piper --
Brouhaha
  • Learning as I go!
« Reply #7 on: April 08, 2015, 08:10:27 pm »
Thanks! Hadn't seen the flickr gallery. That Star Trek cab is exactly what I want to do. Wasn't sure if it was really polycarbonate laminate in that video  :)
Merci :D With all that snow this spring, I get to spend more time in the workshop ;)
Mamezilla
« Reply #8 on: April 08, 2015, 08:47:41 pm »
Bienvenue, et ça me fait plaisir !
You're right...  very nasty winter we had this year.  It won't melt as fast as I'd hope for...
Mamezilla
« Reply #9 on: April 09, 2015, 07:06:33 am »
BTW, if you will be using and supplying your own artwork, I suggest you check with forum member stpcore.  He has done great some work for me and it came out beautifully.  His prices are reasonnable (cheaper than GOG I think), and he's using great quality vinyl.  He can do the polycarbonate laminate CPO you want, and can print your marquee with translite material (which looks awesome !)
Check his threads:
http://forum.arcadecontrols.com/index.php/topic,143964.0.html
http://forum.arcadecontrols.com/index.php/topic,141355.0.html
His youtube channel:  https://www.youtube.com/channel/UCe7yLjuNTVpGrtv04m9VgNw
Might be worth a shot.
I can PM you a couple of pics to show you what he did for my bartop cab if you want.
Brouhaha
  • Learning as I go!
« Reply #10 on: April 09, 2015, 06:49:15 pm »
Thanks for the infos Mamezilla :) Contacted him and will be doing business with him!
Brouhaha
  • Learning as I go!
« Reply #11 on: April 09, 2015, 07:11:04 pm »
Some stuff I received... I feel like a child at Christmas!
From Retroactive Arcade in Edmonton:
  • Xin-Mo 2 player controller
  • 12 Yellow Happ Buttons
  • 8 Black Happ Buttons
  • 1P & 2P Buttons
  • 2 Yellow Happ Competition Joysticks
  • 2 speaker grilles
From Groovy Game Gear:
  • 6 Orange Happ Buttons
  • 2 NovaGemCDR™ Coin Drop Replacement Pushbutton
  • NovaMatrix LINX 2 LED Marquee Light
Mamezilla
« Reply #12 on: April 09, 2015, 08:05:13 pm »
Good !   :)  Ken is a great guy and a pleasure to do business with, you won't be disappointed
Brouhaha
  • Learning as I go!
« Reply #13 on: April 09, 2015, 09:09:00 pm »
So... CP artwork v1:
I want to keep it simple and clean, and so does the wife  :P The joysticks and buttons will do the rest... The Retroclash text will actually be on the front panel of the CP once bended.
johnrt
« Reply #14 on: April 10, 2015, 06:34:12 am »
Nah... it's too boring. Your arcade deserves better. But I see your point here. You didn't make the CP artwork template berfore cutting the button holes, and now it's a pain in the a** making it beacuse you will have to measure where every button and joystick are. But I would do it anyway. My first arcade also has a boring generic artwork, and I regret that today. If you gonna pay for the CP overlay in the first place, make it a good one! And the people on this forum can really help you on the way. They have been around!
« Last Edit: April 10, 2015, 06:37:22 am by johnrt »
RxBrad
  • I like burritos.
    • bit.ly/1GDVYUu
    • RxBrad.com
« Reply #15 on: April 10, 2015, 06:49:28 am »
Honestly, I like it. Curious to see how the rest of the art turns out.
Brouhaha
  • Learning as I go!
« Reply #16 on: April 10, 2015, 07:18:34 am »
Thanks for the feedback guys  :) But it's really that I do want it simple. Wouldn't be a hassle at all to add stuff as the guides for pretty much everything on the CP are in my PS project.
The marquee will be a bit more "flashy"  ;)
No side art on this one. I'm thinking matte black but I'm not settled.
BTW, the t-molding going on it is Pacman orange!
« Reply #17 on: April 10, 2015, 11:55:16 am »
I like the CP idea, Brouhaha. Some people go way overboard on CP art, and really, it's the marquee that should pop.
Brouhaha
  • Learning as I go!
« Reply #18 on: April 10, 2015, 07:27:10 pm »
Thanks yotsuya :) I really like the sticker approach on your Macross cab also! Very authentic  :applaud:
Did they survive the test of time?
« Last Edit: April 10, 2015, 07:28:59 pm by Brouhaha »
« Reply #19 on: April 11, 2015, 01:54:09 am »
Yes, the ones on the CP have been fine. A gluestick has helped with any sticker curl.
I'm taking a similar approach with two cabs I'm working on with for ZapCon next week.  These will be covered with plexi.
Brouhaha
  • Learning as I go!
« Reply #20 on: April 11, 2015, 10:55:16 am »
Thanks! I might just take that route for a few buttons :)
Been working on the marquee:
Or with bigger invaders?
Printing these is getting closer!  :cheers:
« Last Edit: April 11, 2015, 11:28:22 am by Brouhaha »
bfauska
« Reply #21 on: April 11, 2015, 11:48:24 am »
Big invaders.
RxBrad
  • I like burritos.
    • bit.ly/1GDVYUu
    • RxBrad.com
« Reply #22 on: April 11, 2015, 09:24:32 pm »
Big invaders.
Agreed. And, awesome.
Be aware that your marquee retainer will probably cover some of the top and bottom of the art, so you may want to consider extending the background gradient color a bit more beyond the black border on the top/bottom.
« Last Edit: April 11, 2015, 09:31:10 pm by RxBrad »
  • Last login:Yesterday at 04:30:47 pm
« Reply #23 on: April 12, 2015, 12:17:45 am »
Big invaders
I would flip your gradient to match your cp. I would also put some boxes around the controls on the cp artwork. List them as player 1 and  player 2. The cp is just a bit too generic. I get that you want to keep it simple but control boxes look nice.
Brouhaha
  • Learning as I go!
« Reply #24 on: April 12, 2015, 10:36:49 am »
Good suggestions everyone :) I tried most of them, but here's what I'm sending off to print!
Marquee:
Control Panel:
Black invaders are more badass. The one on the CPO are right before the curve to the front panel  :cheers:
camperman73
  • Last login:February 26, 2016, 11:38:31 am
« Reply #25 on: April 13, 2015, 04:03:27 am »
Looks great. Black is better. Looks meaner!
Brouhaha
  • Learning as I go!
« Reply #26 on: April 13, 2015, 09:10:32 pm »
Small weekday update. Finally made what I think are the last holes in the cab...
Coin drop replacement pushbuttons:
Almost time to slot for t-molding  :)
ARTIFACT
« Reply #27 on: April 14, 2015, 09:00:22 pm »
Heyyy Artifact here :) honored that you got inspired by my cab. Looking good so far I'll make sure to follow your progress  :cheers:
Brouhaha
  • Learning as I go!
« Reply #28 on: April 15, 2015, 10:10:54 pm »
Thanks Artifact :)
Big week at work right now... But I just gotta paint that cab soon! So I took a small hour to finally cut the t-molding slot tonight:
So cool to be doing this myself after reading about so many projects! A bit of sanding then I'm priming  :woot
Brouhaha
  • Learning as I go!
« Reply #29 on: April 18, 2015, 12:23:19 am »
Friday night, kinda late. Everytime I think I'm about to prime, I think of something (which is good I guess). Today, I discovered t-nuts:
Pounded those in before I start painting so I can undermount my joysticks. Used a 3/4'' bit to drill what was necessary to hammer these in.
Getting the plexi cut tomorrow. And am also REALLY starting to prime (I hope).
Brouhaha
  • Learning as I go!
« Reply #30 on: April 23, 2015, 09:32:08 pm »
So I got around to priming... Only to realize I had done one crappy job filling and sanding imperfections. So it's back to sanding!  :banghead:
Also wasn't satisfied with the screen panel bevel. Re-routed it to my taste. Looks real good (to me at least) now...
grippie
  • Last login:February 28, 2025, 10:00:46 am
  • Genesis Does
    • Optimus Meatron
« Reply #31 on: April 23, 2015, 10:52:06 pm »
Nice work so far, I really like the simple and colorful artwork. I bet it will pop and look sweet.
Brouhaha
  • Learning as I go!
« Reply #32 on: May 01, 2015, 08:00:11 am »
Thanks grippie! Can't wait to see the marquee backlighted. Ordered the prints from stpcore  :cheers:
Small update, but i finally got that first real coat on! Semi-gloss black enamel using a foam roller. Sanding with 200 grit for the first two coats, then switching to 400 grit to finish it off  :)
Brouhaha
  • Learning as I go!
« Reply #33 on: May 08, 2015, 05:03:35 pm »
Received my prints from stpcore today! Wow!!!! Translite pops simply put on a window!!!  :applaud:
Mamezilla
« Reply #34 on: May 14, 2015, 06:20:58 am »
Glad you seem to be happy with stpcore's prints.  Yeah, this translite material just plain rocks !  And Ken has been a pleasure doing business with on my part.  A great guy and asset for our community
reptileink
  • An 8 bit hero
« Reply #35 on: May 14, 2015, 10:23:41 am »
How hard is it to cut the t-molding "trench" while assembled? I would think it 100 times easier when cutting the panels, no? Do you lay it down?
Brouhaha
  • Learning as I go!
« Reply #36 on: May 14, 2015, 10:41:53 am »
Thanks to you for the heads up! It was indeed a pleasure and very straightforward doing business with him. Will definitly give him props in his marquee topic  :applaud:
Yep, I laid it down on each side, kinda like how you would laminate an assembled cab. Routing at 27.5'' height wasn't ideal but very manageable! And I didn't have to clamp it down and worry about the panels moving while slotting because it is quite heavy (thanks to my 2x3 frame). I will definitly do it that way again on future builds.  :cheers:
Brouhaha
  • Learning as I go!
« Reply #37 on: November 09, 2015, 02:45:14 pm »
So, now that RV'ing season is over and that I have my weekends back, I'll be continuing work on this shortly.
Small question for you pros: I've come to think that the seventh button, well, annoys me. Would Bondo be the way to go to fill it up without having to start the panel over?
Token
« Reply #38 on: November 09, 2015, 03:33:12 pm »
Don't start over. Bondo or wood-filler will work.
mgb
  • North East, US
« Reply #39 on: November 09, 2015, 09:25:55 pm »
This cab is looking great.
I love the shape of the cabinet
