Author Topic: Rasp Pi and Scan Line generator  (Read 4057 times)
j1345
  • Last login:April 12, 2020, 03:38:08 am
« on: April 03, 2015, 10:57:25 am »
Newbe Question again:
When I get the Pi2 do I need to pick up a HDMI to VGA conveter to use the Scan Line Generator?
nitrogen_widget
  • Last login:November 19, 2025, 07:10:59 am
Re: Rasp Pi and Scan Line generator
« Reply #1 on: April 03, 2015, 02:05:46 pm »
yes.
I suggest an active converter an a powered hub.
I had very little luck with passive adapters on the RPI and my SLG didn't work with them.
I'd just get a blank screen or didn't get the scan-lines.
I assume it's because there just wasn't enough signal power coming off that setup.
I have a powered/active adapter the other day so i'll see how that works next week.
