Author Topic: Makvision C2929D vertical issues  (Read 1924 times)
RichSorr
  • Last login:August 29, 2015, 07:27:00 pm
« on: April 02, 2015, 07:40:04 pm »
I have a Makvision 2929d4gts that has a thin horizontal line towards the top of the screen. I found resistor R172 burnt up. I replaced the 1.5 ohm 1/2 watt resistor and a few caps that looked iffy but the same resistor starts heating up again right at power up.
any suggestions? possible tda8172?
thanks in advance
grantspain
Re: Makvision C2929D vertical issues
« Reply #1 on: April 03, 2015, 05:09:46 am »
if you have the crt is mounted horizontal then yes the vertical deflection ic will be the problem
