Author Topic: Master System & Mala  (Read 4985 times)
Beaps
  • Last login:July 09, 2020, 10:46:40 am
« on: March 28, 2015, 11:38:33 am »
Hi All
I am having problems starting Master System in MALA. Megadrive works fine but when I start MS I just get a black screen?
Any ideas?
bmanbdaman
  • Last login:May 09, 2018, 10:03:23 pm
Re: Master System & Mala
« Reply #1 on: March 28, 2015, 10:42:25 pm »
It depends on the emulator you are calling. I use Fusion.
Execution Command Line:
"%path%\%rom%.%ext%" -sms -auto -fullscreen
Beaps
« Reply #2 on: March 29, 2015, 06:17:36 am »
I am using Fusion & I do heave that settling "%path%\%rom%.%ext%" -sms -auto -fullscreen
Its just weird as Genesis works but Master System don't?
bmanbdaman
« Reply #3 on: March 29, 2015, 08:21:50 am »
Turn on logging. Try the command MALA performs manually. Set the correct working directory and check for a typo.
Code: [Select]
2015/03/29  06:13:26.79   Info: CtrlStartGame: EMU_OTHER: emu.FCommandline (config) = "%path%\%rom%.%ext%" -sms -auto -fullscreen
2015/03/29  06:13:26.79   Info: CtrlStartGame: EMU_OTHER Converted Commandline = Fusion.exe "e:\Gamestuff\_retro\segams\game\roms\Double Target - Cynthia no Nemuri (Japan).zip" -sms -auto -fullscreen
2015/03/29  06:13:26.79   Info: Starte: Dir = ..\..\_retro\_emus\sega\
2015/03/29  06:13:39.54   Info: Starte: Ending Game:  >>>>>>>>>>>>>>>>> Quit:
Beaps
« Reply #4 on: April 07, 2015, 05:44:42 am »
OK I got it starting in full screen but it keeps going to windowed when I exit back to Mala. I have separate folders for Genesis/32x & Master System and they exit back fine, it just MS.
Is there an option in the .ini that I can move the Esc key (full screen to window) to a different input?
Thanks agan
Beaps
« Reply #5 on: April 08, 2015, 05:16:56 pm »
Please can someone help me, it's driving me up the wall.
Is it a bug in Mala maybe?
bmanbdaman
« Reply #6 on: April 08, 2015, 09:59:50 pm »
Thanks agan
Fusion - Options - Disable Key shortcuts
Slippyblade
« Reply #7 on: April 09, 2015, 06:21:35 pm »
I was confused by this post till I read Bmanbdaman's post.  His way is the way to do it.  I'd forgotten that I'd done that a long time ago.
