Author Topic: Inserts for MDF  (Read 2793 times)
D_Harris
  • Last login:September 25, 2024, 10:06:48 pm
Inserts for MDF
« on: March 04, 2015, 04:32:15 pm »
Can I get advice for the best inserts for use in MDF?
I made controls panels out of the material used in counter-tops and need to mount the joysticks in a routed out portion and was looking at the inserts at GGG and Ultimarc. They are not the same. One set is flanged and the other is not.
Any recommendations would be appreciated.
Thanks.
Darren
My collection:Asteroids, Joust, Millipede, Ms. Pac-man, Pole Position, Robotron 2084, Star Trek, Star Wars, and 100+ PCBs. Trading/Selling:Arkanoid: R.O.D. Cocktail, Tornado spinner, Hewlett Packard 16500A Logic Analysis System with Accessories. Wanted:Mach 3 joystick. Millipede Trackball. 100° or WG4600 monitor Tube.
  • Last login:Yesterday at 05:29:30 pm
Re: Inserts for MDF
« Reply #1 on: March 04, 2015, 05:52:00 pm »
Both kinds work fine since the outer threads are the wide/flat/thin kind described here in the FAQ.
The kind to avoid for MDF are the ones with outer threads that look like normal screw threads.
D_Harris
Re: Inserts for MDF
« Reply #2 on: March 19, 2015, 08:41:50 pm »
Thanks.
And about the insert/screw material. What is the best between Zinc, Stainless, Brass, & Black oxide?
Thanks.
Darren
