Author Topic: Gorf goes crazy on startup  (Read 2166 times)
Scottacus
  • Last login:November 29, 2019, 01:11:39 pm
  • You will meet a Gorfian doom Space Cadet...
« on: February 25, 2015, 10:03:52 am »
Here is a problem that I can't figure out and I wonder if anyone else has come across this one.  When I first apply power to the Gorf game it continuously cycles the coin meter a couple of times a second, displays the start up screen with two player scores on it and has choppy audio.  If I turn the power off momentarily and reapply power, everything starts up just fine so I have a work around if I can't fix this.
I recapped the power supply and get correct voltage out for all voltages except -5v which I can't get any closer than -5.1v to the -5v.  I read up on the Z80 cpu and it needs to see 0v to reset and then +5v to run.  My brother who is an EE looked at the linear power supply schematic and said that there is a timing RC circuit in there that looks like it does just that.  I only have a digital volt meter so I can't see this 0v pulse.  I also checked out the coin meter and it needs pulsed 9v to make it cycle so a pulse must be going down that wire.
Anyone ever see anything like this?  I have a different set of boards coming from an e-bay auction so I will try those out when they come.
SavannahLion
Scottacus
Re: Gorf goes crazy on startup
« Reply #2 on: February 26, 2015, 05:18:15 pm »
Everything seems to keep coming back to the 0066-117xx chip doesn't it?  It is interesting that my test screen also shows an "X" on it...
Thanks for finding this!
Scottacus
« Reply #3 on: March 02, 2015, 10:08:48 pm »
New (old) CPU board and now no crazy coin counter.  Hope this helps someone in the future.
