Author Topic: Ultimarc Trackball and Golden Tee PCB Board  (Read 1445 times)
davijc02
  • Last login:September 24, 2015, 12:41:33 pm
« on: February 23, 2015, 02:14:17 pm »
Recently ordered an Ultimarc Utrak and am wondering if I will be able to connect this two a golden tee pcb and if so how would I go about doing it? Would I just splice the wires of does a harness exist in which I could use?
lilshawn
  • Last login:December 15, 2025, 02:24:06 pm
Re: Ultimarc Trackball and Golden Tee PCB Board
« Reply #1 on: February 23, 2015, 02:31:56 pm »
yep, it'll splice right in provided you bought the regular version and not the USB version.
Conn A Red   5 Volts
Conn A Black   GROUND
Conn A Purple   X1
Conn A Blue   X2
Conn B Red   5 Volts
Conn B Black   GROUND
Conn B Yellow   Y1
Conn B Green   Y2
davijc02
« Reply #2 on: February 23, 2015, 02:39:53 pm »
I did buy the USB version. Think I can use wiretaps to splice in without cutting off the connector?
davijc02
« Reply #3 on: February 23, 2015, 02:41:30 pm »
Also, this unit has two 5v wires and two grounds. I think the Happ that its intended for only had one of each ground and 5v. Would I just splice the two 5v volts together with the 5v wire from the golden tee pcb and same thing with the ground?
