Author Topic: PS2 japanese question  (Read 3177 times)
Shieldwolf
  • Last login:November 16, 2020, 12:48:53 am
  • SpearShield.com
« on: December 22, 2003, 03:33:12 pm »
I have a great offer on a jap ps2 I want to play jap. games but also want to play us games. do mod chips work reversly so I could play us games?
BombProofPlane
  • Last login:February 11, 2009, 04:14:14 pm
Re:PS2 japanese question
« Reply #1 on: January 02, 2004, 04:19:49 am »
yes but its very hard to put in a chip that doesn't need a swap trick.
you have to actually put wires on those little wires that hold a chip on the mobo
on the other hand the swap chips are real easy
hooded_paladin
  • Last login:November 06, 2013, 08:59:01 pm
  • Finch! hahaha
« Reply #2 on: January 08, 2004, 11:02:18 am »
yes, they do.  If you feel comfortable soldering a chip by yourself, you could get a modchip for $40.  If you don't, you could get a chip and installation service for $100 or so.
There are also fliptops - it's a replacement cover for the PS2 that lets you take a CD out without using the eject button.  You use this with a disc like Swap Magic, which boots up then prompts you to swap discs using the cover.  (pressing the reject button makes the PS2 re-read the region code of the disc, making the swap disc unusable)
However, since the swapping method takes time, you'd probably prefer to get a US PS2 and only swap for Japanese games.
There are even more considerations, though.  A mod chip would boot all games, but PS1 games (from both regions, I think) have extra mod detection that you need to use gameshark codes to eliminate.  Swap discs only play PS2 games.  You need a Gameshark to play PS1 games, and that requires going through the menus and enabling both ignoring the region code and the anti-mod-detection codes.
(this thread has helped me out a lot)
There is SO a spoon.
pmc
  • Last login:December 20, 2023, 07:43:02 am
    • website
« Reply #3 on: January 10, 2004, 07:44:45 pm »
A related question...
I have a PS1 (it's a 7500) and have been thinking about modding it. I know that you can find parallel plug-in mods as cheap as soldered ones. If so, why does anyone bother to open their PS1 up? I'm OK with soldering and all that, but why bother?
