Author Topic: Have any of you guys ever built an entertainment center? Cut sheets.  (Read 4605 times)
Louis Tully
« Last Edit: February 12, 2015, 07:26:43 pm by Louis Tully »
Louis Tully
Have any of you guys ever built an entertainment center? Pics added.
« Reply #1 on: February 05, 2015, 09:32:08 am »
« Last Edit: February 12, 2015, 07:26:54 pm by Louis Tully »
  • Last login:Yesterday at 10:30:56 pm
Louis Tully
Re: Have any of you guys ever built an entertainment center?
« Reply #3 on: February 05, 2015, 09:54:24 am »
« Last Edit: February 12, 2015, 07:27:02 pm by Louis Tully »
jennifer
« Reply #4 on: February 05, 2015, 01:50:29 pm »
    Rather than use trim when finished, I think I would make the whole thing from planed/jointed high end wood.
Louis Tully
« Reply #5 on: February 05, 2015, 03:35:39 pm »
« Last Edit: February 12, 2015, 07:27:07 pm by Louis Tully »
kiel0909
  • Last login:May 23, 2022, 02:59:10 pm
« Reply #6 on: February 05, 2015, 08:19:45 pm »
I built an "entertainment center" using a pocket jig.  However, I already had an alcove in the wall and was simply finishing it out.  its a glorified bookcase. i installed some led light strips under the trim. and im adding glass cabinet doors to the bottom 2 shelves, thats why the bottom shelf is recessed 1 inch behind the trim
Louis Tully
« Reply #7 on: February 06, 2015, 05:33:05 am »
« Last Edit: February 12, 2015, 07:27:19 pm by Louis Tully »
jaharr01
« Reply #8 on: February 06, 2015, 06:36:33 am »
Have u thought about encosing all ur equiptment where it is not viewable then use an IR extender. I have mine in my closet and all you see is the TV on the wall. You could still build an entertainment center though for the TV.
jaharr01
« Reply #9 on: February 06, 2015, 06:41:34 am »
Louis Tully
« Reply #10 on: February 06, 2015, 09:13:39 am »
« Last Edit: February 12, 2015, 07:27:25 pm by Louis Tully »
jennifer
« Reply #11 on: February 06, 2015, 10:06:16 am »
    ***Jennifer laughs, and laughs.... Whatever.... I wish it was that easy to kick the arcade thing, therapy maybe? ***Jennifer laughs some more,  OMG.... But anyway you would probably enjoy perusing a fine woodworking magazine (or two), Might even find the plans for your build.
kiel0909
« Reply #12 on: February 06, 2015, 10:33:48 am »
I built a fish tank stand and used door casing trim around the top, here are some not so great shots of it, its only about 2 inches wide, might work for you?
Louis Tully
« Reply #13 on: February 07, 2015, 07:39:10 am »
« Last Edit: February 12, 2015, 07:27:38 pm by Louis Tully »
jennifer
« Reply #14 on: February 07, 2015, 11:37:27 am »
    Its basically only 3 assemblies joined together with a top board.... That top however will look nice if you do it like the pic, a bit wider than the cab sides.... See how easy that was, there's your accent trim. ;)
Louis Tully
« Reply #15 on: February 08, 2015, 08:05:00 am »
« Last Edit: February 12, 2015, 07:27:46 pm by Louis Tully »
BorgDog
Re: Have any of you guys ever built an entertainment center? Cut sheets.
« Reply #16 on: February 08, 2015, 11:33:16 am »
looking good.  For layouts on plywood I use a simple program called Cut List where you input your sizes and what wood you have and it optimizes the layout.  http://www.delphiforfun.org/programs/cutlist.htm  There are more pro versions you can buy, but for simple projects this one works great.
My Projects:
Louis Tully
« Reply #17 on: February 08, 2015, 01:05:26 pm »
« Last Edit: February 12, 2015, 07:27:51 pm by Louis Tully »
EvilNuff
« Reply #18 on: February 09, 2015, 03:42:01 pm »
Check out lumberjocks.com that site has oodles of woodworking projects people have created.  Great place for ideas.
Louis Tully
« Reply #19 on: February 09, 2015, 04:03:29 pm »
« Last Edit: February 12, 2015, 07:27:59 pm by Louis Tully »
Generic Eric
« Reply #20 on: February 09, 2015, 04:36:24 pm »
If its not too late, have you considered modeling your TV, VCR and atari on the shelves to see how they fit?  Will you have enough shelves for all of the tapes?
Have you considered accent lighting for your gadgets?
Louis Tully
« Reply #21 on: February 09, 2015, 04:50:29 pm »
« Last Edit: February 12, 2015, 07:28:04 pm by Louis Tully »
