Author Topic: Mame 157 - None of the System 1 games work? Is there an updated Atarisys1 bios?  (Read 8165 times)
barakawins
  • Last login:February 01, 2015, 01:44:42 pm
I'm stumping myself here. I'm running mame 157 and noticed that all the system one games don't work. Indiana Jones, Roadrunner, Marble Madness, roadblasters just to name a few. Is there some new atarisys1 bios that I don't know of? It seems like it can't find the bios.
error is: 136032.103.f7.bin not found tried in marble atarisys1 marble.
This same error is generated for all system 1 games. Hopefully someone could point me to the correct bios that incorporates this updated file
  • Last login:Today at 02:59:30 pm
IF you insist on running the latest/greatest version of MAME you'll need to keep up with the changes in the ROMset -- it may not be worth the effort, especially now with monthly releases.
You may find it easier to match your version of MAME to the ROMset you already have.
The 0.157 What's New file here mentions several updates to Atari files including this:
-Add missing Atari System 1 TTL Motherboard PAL.  [Kevin Eshbach]
Where do you find the file(s) you need?  See #5 here then ask River Song.   >:D
DudeRegular
I am seeing the same issue with 157 (157 romset and 157 groovymame). My older 151 set seems to work ok though. I got the new set to use a newer version of groovy and try out some of the new shooter games that were recently supported.
Running one of the games in 151 command line still gripes about the file mentioned above but runs saying the game might not run correctly.
DudeRegular
I had the 156 rom. The atarisy1 rom was updated in 157. Get that and you will be golden. I re-read what PL1 posted and decided to take a second look at my roms. Turns out I didn't have my stuff quite right. Thanks!
Glad to assist.   :cheers:
