Author Topic: New GroovyMAME user :)  (Read 11467 times)
adder
Re: New GroovyMAME user :)
« Reply #40 on: September 01, 2015, 09:05:20 pm »
Quote from: MK
....it creates a modeline with the exact resolution at slower refresh rate but not that slow (around 57hz)....
if you are using an arcade monitor it should be able to cope with higher scan rates than usual. that would mean you can get closer to 60hz
you can try, by changing:
crt_range0                15625-15750, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.192, 1.024, 0, 0, 192, 256, 448, 512
to:
crt_range0                15625-16400, 49.50-65.00, 2.000, 4.700, 8.000, 0.064, 0.192, 1.024, 0, 0, 192, 256, 448, 512
if you dont get a working/stable picture, you could try to go lower, eg:  16300 ...  16200 ...
adder
« Reply #41 on: September 01, 2015, 09:14:14 pm »
Quote from: haynor666
.....Since my TV does not have option to resize horizontally (I know it's weird).....
unfortunately i have used many different brands of tv and have found this to be very common. perhaps out of 10 tv's i would try, maybe 3 would allow horizontal resizing. currently i use a really good JVC tv, allows many adjustments... but no horizontal resize.
  :dunno
Doozer
  • Last login:June 12, 2023, 09:19:49 am
  • Z80 ERROR
« Reply #42 on: September 02, 2015, 07:01:51 am »
Hi,
There is a coil on the chassis that is used to scale the picture on the horizontal axis. (look here: http://www.arcaderepairtips.com/2010/04/21/adjusting-the-horizontal-width-coil/)
DO NOT USE METAL TOOL, USE PLASTIC TOOL
Good luck
adder
« Reply #43 on: September 02, 2015, 11:31:24 am »
Quote from: Doozer
iirc i dont think that's present on all tv's, but sometimes/more likely present on older tv's
