Author Topic: Slim NoName Multicade - Moving along  (Read 16367 times)
ChanceKJ
Re: Slim NoName Multicade - (Update)
« Reply #40 on: February 09, 2015, 08:01:59 pm »
Make sure it's level?
But seriously. I got kinda lucky that mine turned out like it did. I basically did the measurements on the fly between both side panels, yet everything turned out square. take your time, measure, and use the display itself as a reference.
otsep
  • Last login:September 28, 2025, 02:53:45 pm
  • I'm your huckleberry...
« Reply #41 on: February 09, 2015, 08:40:05 pm »
I'm torn between centering it vertically or moving it to the upper half a bit.
Vids: Namco Rockin' Bowl-O-Rama
Pins: Aerosmith Pro, ST Premium Vault, Beatles Gold
Remember Wheaton's Law
yamatetsu
  • Last login:February 26, 2026, 02:07:40 am
  • Just because.
« Reply #42 on: February 09, 2015, 09:58:21 pm »
Just make a mockup. Stand the sides of the cab up at the distance of the cab's width.
Place yourself in front of the 'cab', hold the monitor at the height/angle that is most comfortable for you, mark the position on the cab's sides.
Placing the monitor onto something, a pile of books, whatever, does help.
Note that standing in front of the cab and sitting in front of it makes a difference on the viewing angle, i.e. you'll get a perfect viewing angle standing at the cost of a not so good one sitting, and vice versa.
Just experiment until you find your best placement, there's no general rule for placing the monitor.
It will of course look best if it sits squarely between the sides, but if that means that you don't get the best viewing position, I wouldn't do it. In the long run, it will be no fun to have a cab that looks terrific but gives you neck cramps after playing five minutes.
And finally, before doing anything permanent, just post what you are going to do and see what the folks here have to say about it, they will point out any gross mistakes  ;)
otsep
« Reply #43 on: February 10, 2015, 12:08:56 am »
This sounds like and engineering challenge.  Hmmm...  A motorized adjustable mount?  >:D
yamatetsu
  • Just because.
« Reply #44 on: February 10, 2015, 06:00:59 am »
Nah, the difference between standing and sitting isn't that big. Just figure out if you will be sitting or standing while playing, position the monitor accordingly and you're golden. You are of course free to overengineer it  :)
otsep
« Reply #45 on: February 10, 2015, 06:28:13 pm »
I had a fairly productive day today..
I was able to get the base, sides and a couple of other pieces together and it's upright!  ;D
Angle
Deck blank for comparison.
Approximate placement of the display.
I'm pleased with how it's turned out so far.
otsep
Re: Slim NoName Multicade - (It's upright!)
« Reply #46 on: February 12, 2015, 11:19:07 am »
Yikes! In a rush to finish, I made a miscalculation with the marquee measurements!   :hissy:
Fortunately, I noticed it and was able to correct it last night.
[/url]
otsep
« Reply #47 on: February 13, 2015, 12:00:27 pm »
So I thinking about the audio system and was looking for feedback.  Should I just run with a PC audio solution and then hack the controls or run with a automotive-like setup?
« Reply #48 on: February 13, 2015, 12:01:48 pm »
PC audio is fine unless you're one of those guys who think this would also make a good jukebox.
a1pharm
« Reply #49 on: February 13, 2015, 12:11:17 pm »
PC audio FTW.
I have Logitech Z313 Speaker System in my cab ($35).  They put out great sound.  Has a wired remote that makes hacking the volume controls very easy.
I have Logitech Z623 Speaker System attached to my desktop ($120).  They put out the best sound you can probably every hope for in a cab.  The issue with these would be hacking the volume and bass controls.  It can be done, but you should be fairly confident in your wiring skills before taking this on.  These are THX certified in case you care about that sort of thing.
If I were to redo my cab today, I'd use the Z623 system.
otsep
« Reply #50 on: February 13, 2015, 04:18:37 pm »
PC audio FTW.
Did you de-case the speakers?
a1pharm
« Reply #51 on: February 13, 2015, 05:10:22 pm »
PC audio FTW.
Nope.  Decasing low wattage speakers is kind of a waste (as long as your speaker grill/opening is larger than the speaker itself...) in my opinion.
ChanceKJ
« Reply #52 on: February 14, 2015, 01:52:20 am »
PC audio FTW.
Agreed, There's really no need.
otsep
« Reply #53 on: February 17, 2015, 01:34:57 pm »
Ordered some speakers and I'll be ordering all the controls today.
Quick question..  Circular or Octagonal restrictor for the UltraStiks?
I was leaning more towards the octagonal, but I'd love to know what the experience has been out there.
ChanceKJ
« Reply #54 on: February 17, 2015, 01:56:24 pm »
Octagons.
Circular just reduce the throw. My biggest beef with the 360s are the lack of feedback for my hand eye coordination. I added microswitches to both of mine to give the same sensation and feel/sound of the "click" on my J-Sticks I have at P3/4.  I'm adding Octos next. Could add tougher springs to them as well, Neph swears by them.
otsep
« Reply #55 on: February 17, 2015, 05:14:58 pm »
Since the UltraStik shafts also work on the JLW, I wonder if you can use this on the UltraStik?
http://www.paradisearcadeshop.com/shafts/728-jlw-10mm-stainless-steel-hollow-joystick-shaft.html
otsep
« Reply #56 on: February 19, 2015, 03:22:00 pm »
Got an Ultimarc order today ;D
Two 360's and a U-Trak
otsep
« Reply #57 on: February 22, 2015, 05:54:23 pm »
Been in single parent mode and haven't been able to to any more work on the cab, so I focused on the systems.
I added the hard springs to my U360s and spent the desk time rebuilding the computer from scratch with a fresh HyperSpin install.  Things have been moving along nicely and I hope to work on the cab this week coming.
otsep
Re: Slim NoName Multicade - Software Build
« Reply #58 on: February 24, 2015, 09:40:52 pm »
I was able to get most of the emulators setup that I wanted to use. But could really use some help with Daphne.
OS: Windows 7 Professional 54-bit
FE: HyperSpin
Emulators:
  • MAME 64 v0.158 (No Nag & High Score)
  • Nintendo Entertainment System
  • Nintendo Game Boy
  • Nintendo Game Boy Color
  • Nintendo Game Boy Advance
  • Sega Genesis
  • Sony PlayStation
  • Super Nintendo Entertainment System
Missing:
  • Daphne - This one has been giving me some trouble.
  • Sega Dreamcast?
  • Nintendo GameCube?
Misc:
  • HyperLaunch
  • Don's HyperSpin Tools
  • LED BLinky
  • Macrium Reflect Free
I'm a big fan of Macrium Reflect as a device imaging solution. Using a bootable USB drive, I can easily make full images of systems.  I currently have a base OS + updates and one from this morning with the current build including ROMs and media.  The end goal will be to have an bootable USB key that can completely reset the system in case something/someone goes nutty.
« Last Edit: February 24, 2015, 10:00:14 pm by otsep »
tkersting
  • Last login:April 26, 2015, 08:34:52 pm
Re: Slim NoName Multicade - Computer setup
« Reply #59 on: February 24, 2015, 10:35:14 pm »
Looking good
otsep
« Reply #60 on: February 25, 2015, 10:07:20 am »
Looking good
OnePunchRob
  • Last login:February 26, 2024, 07:52:42 am
« Reply #61 on: February 25, 2015, 10:17:43 am »
What help do you need with Daphne?  I'm no expert, but I have managed to get Dragon's Lair 1&2 and Space Ace working fine.
otsep
« Reply #62 on: February 25, 2015, 10:19:05 am »
Yes.  Yes I do.
OnePunchRob
« Reply #63 on: February 25, 2015, 10:40:33 am »
What problem are you having with it exactly?
otsep
« Reply #64 on: March 01, 2015, 08:15:15 pm »
Got Daphne working except for Dragon's Lair doesn't always flash when it should.  I'm guessing my mpeg is a little messed up.
otsep
Re: Slim NoName Multicade - Back to building
« Reply #65 on: March 03, 2015, 10:02:24 am »
I'm back to building today. :)
My focus is all the remaining odds & ends, vent holes, speaker holes and control panel.
I found a great option for vent grilles @ Home Depot - 5 in. x 3 ft. Black Lock-on Gutter Guard
http://www.homedepot.com/p/Amerimax-Home-Products-5-in-x-3-ft-Black-Lock-on-Gutter-Guard-441-503/203649434?N=5yc1vZar5e
It's already coated black and easy to cut.  ;D
 I'm hoping to have it all wrapped up today or tomorrow so I can start painting.
otsep
Re: Slim NoName Multicade - Back to Building
« Reply #66 on: March 03, 2015, 02:53:52 pm »
Banged out the vents and speaker holes this morning.
Put a small chamfer on the edge for a nicer transition.
ChanceKJ
« Reply #67 on: March 03, 2015, 04:59:10 pm »
 :applaud: chamfer
/AppleThings  :D
« Reply #68 on: March 03, 2015, 05:05:12 pm »
ChanceKJ
« Reply #69 on: March 03, 2015, 05:19:11 pm »
To the general public, yeah probably. There's a massive spike in the Google Trends Sept 2013 when you search "Chamfer Edge". ...same month the iPhone 5 launched.
otsep
« Reply #70 on: March 03, 2015, 06:04:24 pm »
I need to tackle the marquee tomorrow.  When I was setting everything up I made a poor choice on some of the angles and speaker panel end too close to the front edge of the bottom of the marquee.  :banghead:  Sooo.... I think I'll leave a small gap and use magnets to secure the marquee holder in place.
Hopefully it will work or I'll end up just screwing in the bottom permanently and accessing the panel through the top.  :dunno
If anyone has any better options, I'll all ears.
ChanceKJ
« Reply #71 on: March 03, 2015, 06:09:31 pm »
Screws arnt permanent.  How often will you change the marquee? Honestly. Nintendo Cab marquee brackets were screwed down and ment to be changed periodically. :).  Just screw it down. No big deal :)
otsep
« Reply #72 on: March 03, 2015, 06:15:25 pm »
Probably right.  I need to find the right screws and inserts for 1/2" MDF.  The only ones at the big box way too long.  I currently have some hanging ceiling tile braces I was going to use for the bezel.
a1pharm
« Reply #73 on: March 04, 2015, 08:01:47 am »
I copied martijn and use T-nuts in all my top marquee rails
« Reply #74 on: March 04, 2015, 09:48:10 am »
Actually, 99% of the games BITD used T-Nuts.  :cheers:
otsep
« Reply #75 on: March 06, 2015, 10:53:50 pm »
Been busy with work and the family so I haven't made much progress.  I was able to get the back panels finished,
a1pharm
« Reply #76 on: March 07, 2015, 07:44:08 am »
Looking slick, you're getting close!
otsep
Re: Slim NoName Multicade - Messed up! Need Help!
« Reply #77 on: March 15, 2015, 01:33:37 pm »
So... I messed up.  Somewhere along the line, I screwed up the area where the Speaker panel meets the marquee.   :badmood:
Whether I measured incorrectly or built wrong, I'm not sure.   :banghead:
My panel now buts up against the marquee and I cannot fasten is an intended.  :cry:
The batons are glued and screwed in place and will be a royal pain to remove.
The marquee holder is a Ceiling Tile Wall Molding, not not easily shaped beyond basic cutting.
I have some ideas, but I would really love some input/guidance. :notworthy:
  • Cut holes in the top of the speaker panel to access the screws. (Ugly)
  • Attach the lower marquee holder to the speaker panel. (Not sure how)
  • Build a frame to hold the plexi and attach to the front of the leading edge of the marquee box. (somehow)
  • Kill it with fire
As usual, any input/guidance the community would be able to provide would be greatly appreciated.
ChanceKJ
« Reply #78 on: March 15, 2015, 01:53:52 pm »
Kill it with fire.
This is good, screw down the Lowe marquee bracket from the top, inside of the marquee lighting area. Rest the marquee glas into it and screw down the top bracket from the top. The lower bracket can be fixed.
« Last Edit: March 15, 2015, 01:55:45 pm by ChanceKJ »
bfauska
« Reply #79 on: March 15, 2015, 01:55:05 pm »
Could you attach the retainer down to the speaker panel from above by screwing through the bottom part of the retainer into the speaker panel and then slide the marquee in from above and use the top retainer to hold it in? Does that make sense? I can't really sketch what I'm trying to describe because I'm on my cell phone.
