Author Topic: Aimtrak Button 2  (Read 2255 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
Aimtrak Button 2
« on: January 05, 2015, 05:43:57 pm »
Hi folks:
I finally got around to setting up an Aimtrak gun on a cab, and realized that button 2 (the button by the barrel of the gun and not the trigger button) isn't working.  I bought it months ago, so I can't return it for an exchange I don't think.  When I go to MAME <Tab> set up Player 1 controls, for Player 1 Button 1, it registers properly when I press the trigger button, but for Player 1 Button 2, when I press the other button, nothing registers, so I suspect it's broken.
Am I missing something here?
TimeCrisis
  • Last login:July 22, 2023, 04:32:47 am
Re: Aimtrak Button 2
« Reply #1 on: January 05, 2015, 06:19:46 pm »
did you try binding the button.
what happens if you set that button so right mouse button in aimtrack setup, does it work on windows desktop?
Richardgregory
« Reply #2 on: January 05, 2015, 06:28:06 pm »
Tried to bind in MAME, but when I press the button, nothing registers.
In Aimtrak setup utility, I have it configured as follows.
---------On Screen----------Off Screen
TRIG = Mouse LEFT-------Mouse RIGHT
AUX= ----------------------AUX= --------
P1= GP Button 1----------GP Button2
I took apart the gun and the connections look in tact.
I guess I really don't need the button 2 do I?  Do some titles need 2 gun buttons?
TimeCrisis
« Reply #3 on: January 06, 2015, 03:29:23 pm »
you will never need more than 1 button.
I use arcade guns. why is your AUX empty, and what is that.
is P1 your working button, when you fire than inside or outside the screen it will create a different keypress.
do you not have a P2 or some other row in your software, in mine I have
trigger      Mouse left
Left          GP1
Right        GP2
and left and right are my two buttons.
DarthMarino
  • Last login:December 17, 2025, 10:53:45 am
« Reply #4 on: January 06, 2015, 04:39:20 pm »
Definitely looks like you need to map AUX to something in the utility.
Richardgregory
« Reply #5 on: January 08, 2015, 09:35:27 pm »
Gun was flaky....got supplier to replace, now works fine :)
