Author Topic: Electrohome G07-FBO 13-inch All White  (Read 1560 times)
mailman-zero
  • Last login:June 09, 2023, 08:14:46 pm
    • Walking Towel
« on: January 03, 2015, 03:57:12 pm »
I sent this monitor out to be repaired and it came back working great for about a day. The first day everything was working great, but the following day I powered on my Centipede cocktail and got just a white screen. I thought it might be the centipede board not sending the signal correctly, so I swapped out the board with a known good centipede board and it's still doing the same thing.
I can adjust the screen setting, but I don't think that's what's wrong. I am willing to investigate the issue, but I don't know where to start. I've replaced caps and flybacks, etc. so I can do that level of investigation. See the video below for what happens when I adjust the screen setting. Thanks!
grantspain
Re: Electrohome G07-FBO 13-inch All White
« Reply #1 on: January 04, 2015, 06:47:22 am »
have you verified the power supply voltages?
when i first saw the vid of the issue i thought it may be a blanking problem,possibly 200v video b+ missing but as you can adjust screen volts i do no think it is that
only other thing could be beam limiter fault,which i believe is x303-and check x304
i imagine the heater is running?
mgb
  • North East, US
« Reply #2 on: January 04, 2015, 10:33:12 am »
From a quick look at a flow chart, the only reference to bright white on that is the beam limiter transistor x303
