Author Topic: Coin circuit common problems  (Read 3291 times)
vanwatson
  • Last login:January 02, 2015, 09:21:39 pm
« on: January 01, 2015, 05:45:19 pm »
What are the most common problems with the coin circuit and coin mech system?
can you please list the most common problems?
The Coin circuit outputs a +5 volts pulse waveform?
if the pulse waveform output is higher then +5 volts it will damage the coin circuit?
when you insert a coin it triggers the coin circuit
Some Coin mech systems are +5 volts, others are +10volts and +12 volts
What is the difference between them?
Why would I want to put in a +12 volts coin mech system compared to a +5 volts coin mech system?
  • Last login:Today at 02:54:12 am
Re: Coin circuit common problems
« Reply #1 on: January 01, 2015, 05:54:15 pm »
Sometimes a token/coin gets stuck, and kids keep jamming more tokens in, making the jam worse.
Sometimes, someone stick a slug or nickel in and it messes stuff up.
Hope that helps!!!  :cheers:
vanwatson
« Reply #2 on: January 01, 2015, 06:03:37 pm »
What does the arcade technician have to do to the coin mech. system to fix these types of problems?
SavannahLion
« Reply #3 on: January 01, 2015, 06:29:51 pm »
Do you not have the ability to look at the problem and figure this ---steaming pile of meadow muffin--- out on your own?
I was an arcade last night looking at a game my 5yr really wanted to play. Noticed all the coins were jammed in a cluster ---fudgesicle--- at the opening. Slipped the token card in, and squirreled one token out and had two drop into the coin return. I spent more timing fishing the token card out of my pocket than I did getting the jammed tokens out.
There are too many variables to list to give you a satisfactory answer. If you can't work even the most basic problems out you need to rethink your hobbies, job or whatever the hell you do asking questions like this.
lilshawn
  • Last login:October 11, 2025, 02:57:11 pm
« Reply #4 on: January 06, 2015, 01:18:53 am »
open the door and take out the offending coins.
I place them in my pocket. You may or maynot be able to. If I get enough, I go for lunch. if not, I tough it out till the end of the day and wash off the old war wagon at the local car wash...I did this today... as I only got 2 bucks.  :-\
also, it's -20...my doors may be frozen shut now...i may be late for work tomorrow whilst I pry them open. I'll be damned if i'm getting up early.
mgb
  • North East, US
« Reply #5 on: January 10, 2015, 06:24:11 pm »
Another common problem is an improperly adjusted coin switch.
Why would someone want to use 12 volts for the credit circuit?
Before that's what they wanted to do.
