Author Topic: Oscar Restrictors  (Read 3292 times)
bhille
  • Last login:January 02, 2003, 11:39:40 pm
  • Be the ball...err...be the arcade machine...
Oscar Restrictors
« on: June 17, 2002, 12:59:37 pm »
I was looking to put the Oscar restrictors on my wood control panel.  This setup would be without the mounting plate so I can keep the looks as clean as possible.  I would like to use the pegs so it's wasy to swap.  Have people used the pegs instead of the screw mounts?  Would I be better off getting the screw mounts and finding "finger screws" somewhere?  If so, where?
I would just like to hear how other are using these restictors.
Thanks,
Brian
Jakobud
  • Last login:December 09, 2025, 12:11:34 pm
Re: Oscar Restrictors
« Reply #1 on: June 17, 2002, 07:55:13 pm »
I did the same thing as you. I wanted a clean board with no mounting plate. My cp is wood with lexan overlay. So I have holes in the lexan and the wood. Just use the plate as a drilling template.  Anyways, I am using the pegs and they work just fine. No problems.
jake
