Author Topic: No sound from right speaker?  (Read 1964 times)
roseysdad
  • Newbie
  • Last login:December 15, 2014, 03:00:54 pm
« on: December 15, 2014, 02:58:58 pm »
Hello.
My boss recently purchased a RI-5 (Rowe AMi, build 1983) and we're not able to get sound from the tweeter (4 1/2 inch) top right speaker.  The speaker works when hooking it up to the L channel wires.  The L speaker works when hooked up to the L channel using the R speaker wires.  Im guessing that the R channel board is the problem.  How do I narrow it down from there?
lilshawn
  • Last login:Today at 11:45:41 am
Re: No sound from right speaker?
« Reply #1 on: December 16, 2014, 11:57:06 am »
you can try swapping the left and right leads on the pickup head (needle) itself. if the sound switches sides, there is a problem with the pickup. (not uncommon to happen)
if the same side stays dead you probably have a dead output channel. if so, the amp will have to be serviced.
Generic Eric
« Reply #2 on: December 16, 2014, 12:00:01 pm »
That exact thing happened to me on an old turntable/receiver.  Even same right speaker.  I still don't understand what happened and I don't have the speakers anymore.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #3 on: December 18, 2014, 07:06:18 am »
Hello roseysdad,
Welcome to the forum.
If you have found out that the tweeter is ok, if there is a output package fitted on your amplifier (or if a 125/130 watt amplifier is fitted with a separate output package) you need to check that the pink and pink wires are on E6 Left & E6 Right and the black  & Black/yellow wires are connected to E1 feft & right (in the case of the separate output package it is a black wire to E1 right).
Please let us know how you get on.
Regards
Alan
Alan Hood
ami-man
UK
