Author Topic: Sourcing Metal for control panels  (Read 2350 times)
Generic Eric
« on: December 14, 2014, 10:02:42 pm »
Is it possible that metal of a side panel of a dryer, stove or washing machine would be thick enough for a control panel?
BorgDog
Re: Sourcing Metal for control panels
« Reply #1 on: December 14, 2014, 10:59:03 pm »
i would say old ones would be fine, newer appliances not so much.   :angry:
My Projects:
AzureKnight
« Reply #2 on: December 15, 2014, 10:13:32 am »
I would guess no.  When you lightly push on most washer/dryers that I have seen the "pop" in and out pretty easily and make quite a thundery racket.
Maybe if you double up a couple of sheets?
« Reply #3 on: December 15, 2014, 12:36:43 pm »
I think size of panel, and if you are bending the metal at any spot would make a difference as well. I would think you could easily reinforce it in key areas as well.
jennifer
« Reply #4 on: December 16, 2014, 01:10:14 am »
    Your local HVAC guy will have scraps of 16ga. you can pick through.... That or your local metal outlet, they always have a wall of bargain leftovers.
