Author Topic: Problem saving layouts in Mamewah  (Read 1387 times)
daz
  • Last login:March 30, 2019, 01:04:55 pm
  • My cab is almost done!
    • WIP
« on: December 16, 2003, 02:16:10 pm »
I was attempting to setup a SNES and Genesis emulator in mamewah last night and ran across a problem. I was trying to use a different layout file for each emulator and it appeared to be working fine. However when I switched to a different emulator and then back, it was back to the default layout. I tried searching for this problem, didnt come up with anything though. Any ideas?
Jesse
Re:Problem saving layouts in Mamewah
« Reply #1 on: December 16, 2003, 02:28:16 pm »
Could you give some more details, like .LAY filenames, which emulator is which etc...
I can't think of what the problem is from the top of my head, possibly a file naming issue (?)  Some of the guys here might know, I only use 1 layout...
daz
    • WIP
« Reply #2 on: December 16, 2003, 02:52:02 pm »
Thanks, I will post the filenames and layouts when I get home tonight.
Jesse
daz
    • WIP
« Reply #3 on: December 17, 2003, 01:26:59 pm »
Here is how I have it setup currently. I have 3 folders in the layouts folder named mame, snes, and gensis; with the corresponding .lay file and background image. Mamewah starts up with the default layout, I can go into the settings and change it to the folder name and the change does take place with the new layout. when I change to a different emulator and set the layout for that one; say in this case "snes" it swtiches to the correct layout from the snes layout folder. Here is when the problem comes in. If I switch back to the "mame" emulator the layout is the default mamewah layout (the "mame" layout is gone). The interesting thing is that in the mamewah settings, the name of the layout is "Snes". This is the problem that has occured each time I have tried to configure it, even when done in different orders. One thing I have not tried is manually editing the config files which I may try this evening.
Jesse
« Reply #4 on: December 17, 2003, 02:07:58 pm »
Jesse
OK now I see what is wrong:
You only need one 'Layout Name' - lets call it 'Daz' for eg.  So your folder should look like this:
\MAMEWAH\Layouts\Daz
That is the only folder you need, which should contain:
emu1.lay (MAME for eg)
emu2.lay (SNES for eg)
emu3.lay (GENESIS for eg)
...and also background images if required:
(jpg used as an eg).
The 'Layout Name' you enter in MAMEWAH would just be 'Daz'.  This is global and so you do not need to enter a different layout name for each emulator.
The file Layouts.txt explains this ;)
daz
    • WIP
« Reply #5 on: December 17, 2003, 02:50:03 pm »
Yikes. I should have double checked that file.. Thanks much Minwah!
Dave Butler
  • Last login:October 27, 2016, 03:31:16 pm
  • What does this button do?
    • MAMEWAH Setup
« Reply #6 on: December 17, 2003, 04:13:53 pm »
MAMEWAh set-up does the names for you. All in the same folder.
Give it a try.
daz
    • WIP
« Reply #7 on: December 18, 2003, 12:18:22 pm »
Much thanks for the help. I followed the directions (that I should have read) you gave and it worked perfectly.
Thanks Again,
Jesse
