Author Topic: Mame HLSL compilation error with Windows 8.1  (Read 3171 times)
dfwdennis
  • Last login:April 22, 2016, 06:12:23 pm
« on: December 02, 2014, 11:58:00 pm »
One of my Black Friday purchases was a new PC for my Mame cabinet.  It (unfortunately) came with Windows 8.1.  I have everything working fine other than when I try to enable HLSL.  When I do that, Mame crashes on launch with the following error:
Unable to compile shader: hlsl\yiq_decode.fx(133,3): error X6077: texld/texldb/t
exldp/dsx/dsy instructions with r# as source cannot be used inside dynamic condi
tional 'if' blocks, dynamic conditional subroutine calls, or loop/rep with break
ID3DXEffectCompiler: Compilation failed
I tried both Mame 0.152 and 0.156 and both of them have the construct in the yiq_decode.fx source file that is causing the problem.  Is this a compatibility issue between Mame and the latest DirectX?   Has anyone else seen this before?
lamprey
Re: Mame HLSL compilation error with Windows 8.1
« Reply #1 on: December 03, 2014, 01:51:38 pm »
I've not see that error before, so I'm not sure of the cause, but you might try installing the 9.0c end user runtime:
http://www.microsoft.com/en-us/download/details.aspx?id=34429
Also, you didn't mention a video card. I assume that a modern computer would be DirectX compatible. But, if not, there you go. :)
dfwdennis
« Reply #2 on: December 04, 2014, 09:40:58 pm »
Apparently DirectX 9.x is not compatible with Windows 8.1.  I have DirectX 11.2, and tried to install that version as well but it reported that it is incompatible.
IAmDotorg
  • Last login:April 27, 2015, 03:05:37 pm
« Reply #3 on: December 05, 2014, 08:20:20 am »
My cab runs MAME with HLSL just fine on 8.1.
Not sure what to suggest to you, but its something specific with your system, not a 8.1 issue. That may help narrow down the problem.
dfwdennis
« Reply #4 on: December 06, 2014, 05:15:12 pm »
Thanks for that data point!  It definitely helps to know that someone else is successfully running Mame on Windows 8.1.
