Author Topic: WG 19" K7200 Standard Res Monitor and Golden Tee  (Read 1667 times)
ntjedi
  • Last login:June 12, 2009, 04:02:25 pm
  • Who wants to be a firetruck?
« on: December 16, 2003, 10:06:14 am »
I plan on using the monitor for both a PC and would like to be able to switch over to a Golden Tee PCB.  Will this monitor work with Golden Tee?  And from what I understand (please correct me if I am wrong) I should be able to get a cable with a montior connector (0.156 Center Headers) on one end and a JAMMA connector on the other, correct?
 Am I missing anything here? ???
Or could you recommend another 19" monitor that I could use to accomplish this?
« Last Edit: December 16, 2003, 10:08:36 am by ntjedi »
"Genius? Nothing! Sticking to it is the genius! ... I've failed my way to success."
--Thomas Edison
ntjedi
Re:WG 19" K7200 Standard Res Monitor and Golden Tee
« Reply #1 on: December 16, 2003, 08:58:12 pm »
In case anybody is interested this is what I found out so far.
Standard resolution monitors are usable for GT up through 2K. All the GT Fores (2001-present) require medium resolution monitors.
The K7200 is a standard (CGA) monitor.
--Thomas Edison
