Author Topic: Maximus Arcade Theme Editor- Font Bug  (Read 3550 times)
ZexisStryfe
  • Last login:April 22, 2022, 02:24:12 pm
  • Evolution has begun...
« on: November 27, 2014, 08:03:17 pm »
So I have been working on a new theme for Maximus, but seem to have run into an issue due to the number of fonts installed on my system. If I scroll down the font list to a font after #255 I cannot select the font.  :banghead: It instead selects another font (I believe it is actually subtracting 255, so if I select font 300, it gives me font #45 in the list). Has anyone else run into this? If so are there any work around that don't involve me uninstalling all the fonts on my machine?
Thanks,
ZopenkoX
  • Last login:July 17, 2018, 06:48:15 pm
Re: Maximus Arcade Theme Editor- Font Bug
« Reply #1 on: November 30, 2014, 11:25:14 pm »
Never had an issue with the fonts, probably because i don't have +256 fonts installed  :P, but a made a quick test and it work, hope it helps:
- open the theme on the theme editor.
- with the theme editor open, locate the SKIN.INI file on the cache folder
- edit the font name
  look under [rom_title_yourthemedimension] for the titles
  look under [rom_list_yourthemedimension] for the rom names
- change the "family" entry, on the "style" row
     in this example I changed it to arial
     Style=[#family: "Arial", #style: "plain"]
- now save the modified ini file.
- now back to the editor, save you're theme.
- Open back the theme, it should have the new font added, again i do not have 256+ fonts installed, so i hope it does work for you.
Cheers
ZexisStryfe
« Reply #2 on: December 02, 2014, 11:03:39 am »
Thanks Zop, that worked!
