Author Topic: Amount of Buttons?  (Read 925 times)
MadMike
  • Last login:March 04, 2017, 07:13:31 pm
Amount of Buttons?
« on: November 24, 2014, 06:46:02 am »
Hi
I might be doing a first time build of a bartop soon and was wondering how many buttons you need on a control panel, without making it look silly.  I was thinking your standard 6, plus 1 and 2p start, 2x coin for 1p and 2p, enter and exit button and 2 pinball buttons on side?  Its going to be mainly for mame but I want to emulate as many systems as possible, but know I won't have enough buttons really for all.  I'm using a miniPAC and believe you can use a shift button to make other buttons have different functions.  I guess you could use the pinball buttons for 1p and 2p coin.
EMDB
  • Project RetroCade
Re: Amount of Buttons?
« Reply #1 on: November 24, 2014, 06:53:15 am »
You can use Button 1 of Player 1 as Enter button. You can wire the pinball buttons parallel with P1 button 1 and 2.
  • Last login:Today at 08:58:15 pm
« Reply #2 on: November 24, 2014, 08:00:21 am »
If you're planning on running Visual Pinball/Future Pinball, plan your encoder keystroke choices around the defaults for those emulators.
If you don't stick with the defaults for VP/FP, you might end up having to edit scripts to get some tables to work.    :banghead:
Here are the VP/FP defaults and where they overlap with MAME.
Also consider using Goldleaf or GGG Class-X with True-Leaf Pro buttons for the flippers instead of microswitch buttons.   ;D
