Author Topic: Dust / Debris Under Artwork  (Read 1459 times)
newoski
  • Last login:February 26, 2021, 07:44:50 am
« on: November 15, 2014, 11:23:49 am »
Hi Guys,
Just installed my artwork last night, and while I'm happy overall, there are a few tiny pieces of dust/debris that stick up slightly.
Are there any recommended tips for neutralizing these? Can I push down with something, do flatten them etc?
Thanks,
Owen
newoski
Re: Dust / Debris Under Artwork
« Reply #1 on: November 16, 2014, 12:32:51 pm »
Anybody?
Thanks guys!
SavannahLion
« Reply #2 on: November 16, 2014, 02:24:44 pm »
Don't stress if someone doesn't post right away. Just means no one with the answer posted.
IMHO, you're pooched. This exemplifies the use of a clean environment and judicious use of a tack cloth to ensure a clean surface before application.
For most, you'll have to live with the blemish.
There are a few things that can help alleviate the worst but none come without a price to pay. In all, patience is a virtue. Do the work without interruptions. Kick the kids and spouse out of the house, set the phone on silent and leave a note on the door that you've died and you won't be returning.
Use a razor blade or a brand new X-acto blade to cut a very small slit as close as you can to the particle. Try to follow an existing edge in the art if you can. Don't cut the decal at an angle but straight down, then use the tip (X-acto is excellent for this) to "hook" the edge and lift. Cutting at an angle creates a wider profile where there won't be any adhesive on the edge. That edge will lift over time. Carefully hook the particle and pull it out. Gently push the "flap" back down. If you "touch" the adhesive too much, it loses its grip and will likely open up over time. Don't be tempted to use super glue to seal the edge, it's too difficult to do "just enough."
Don't be tempted to cut across the debris. The risk of a messy edge when putting it back together is too much and if the debris explodes as you cut across, you'll never get it cleaned out.
If it's an air bubble, (did you use the wet application method? No? Shame  :whap) steal one of your wife's sewing needles and punch a hole dead center of the bubble. Squeeze the air out.
If it's hair, leave it. I have eight hair producing animals and three human females in the house. The amount of hair that's produced is atrocious. That ---steaming pile of meadow muffin--- gets everywhere. The only real solution is to use copious amounts of fluid to "wash" the hair away before application.
Don't squish the debris down. That doesn't work 99% of the time. You'll have the debris pop up over time and you'll likely mar the art trying to get it flattened.
newoski
« Reply #3 on: November 16, 2014, 02:39:55 pm »
Thanks very much. In all my reading, I never saw mention of using tack cloth. Sounds smart! I'll keep that in mind for future builds. Probably going to live with it on this one, as the debris is super tiny
ChanceKJ
« Reply #4 on: November 16, 2014, 02:46:59 pm »
Unless it's something directly staring at you all day long you'll be ok. I sliced my art during the install at the dead top centre of my CP and had a mini freak out. It was the smallest thing and I just don't see it, ever. Nicked my t-moulding too. Meh.
The overall finished product masks the tiny blemish.
  • Last login:Today at 02:19:10 am
« Reply #5 on: November 16, 2014, 02:52:58 pm »
Chance is right. You'll freak out over it for a week, then after that you won't even remember.
newoski
« Reply #6 on: November 16, 2014, 02:58:28 pm »
Thanks guys -- from past experience (on every phase so far for this build) I'm inclined to agree
  • Last login:July 11, 2025, 09:17:44 am
« Reply #7 on: November 16, 2014, 05:41:51 pm »
Also, don't point it out to friends who are using the arcade machine.  Most won't even notice, at all.  If you mention it to them though...
D
jdbailey1206
« Reply #8 on: November 16, 2014, 06:58:35 pm »
I completely agree with SavannahLion.  Sometimes it helps to have an extra set of hands to pull the artwork tight while you yourself run the squegee down over the artwork.
What I also do and may be a little tedious for some is find a led flashlight and run it over the area you are going to apply the artwork to find of there are any areas that contain dirt particles you may not see with the naked eye.  I then mark these areas and clean as needed.
