Author Topic: Joysticks advice (newbie)  (Read 931 times)
Blueic5
  • Last login:December 16, 2018, 05:31:20 pm
« on: November 15, 2014, 10:53:24 am »
Hi
I've been building my cab for a couple of years now,  anyway I thought I'd start on the Control panel.   I've built the panel based on lusid design and 3/4 "mdf.   So joysticks I'd rather mount from underneath to save routing as I just for now plan to paint and seal the top. Games I like are sf2, final fight etc but want play other games too.   So initially was thinking a sanwa jlf but sounds a faff changing between 4/8 way and I'd need to route the top.   Came across the ultimarc u360's ball tops and they appear to be bottom mountable.   I see they do a top restrictor too which maybe useful and give it a nice feel.   Is this my best bet will the throw be to long?   Do I need to change the spring?   Suggestions please :)  oh and these would save me buying an ipac for now.
Re: Joysticks advice (newbie)
« Reply #1 on: November 15, 2014, 10:55:39 am »
U360. Octagonal restrictor. Stiff spring. Lube the pivot with plumber's silicone grease. You're welcome.
Blueic5
« Reply #2 on: November 15, 2014, 12:37:17 pm »
Thanks,  would I need the longer shaft?   I take it you would go with this over the front mounted restrictor kit?
