Author Topic: NEO-GEO MV-1C White Screen?  (Read 2821 times)
8way
  • Last login:February 03, 2017, 05:52:21 am
  • This is my BOOM stick!
« on: November 09, 2014, 10:53:12 am »
Hi, so I just picked up this MV-1C and its having some problems. When I turn it on, all I get is a white screen and no sound. I tried with and without a cartridge. I tested the voltage all around the board, and it looks good. Visually inspected the board, and I could not find anything that looked bad. Theirs no battery leakage or bad caps. I did notice it had a blown fuse that was repaired by the previous owner. The fuse had a piece of wire soldered across it. So I replaced it with a new fuse. I did some searching and found some info mentioning that it could be the crystal. So I tried changing the 24Mhz crystal, and no change at all. So I don't think its the crystal. What do you guys think? Also anyone know were I can download the operators manual, all I can find is the user manual.
