Author Topic: D9200 screen bowing issues - HELP  (Read 3102 times)
deuceduzit
  • Last login:April 01, 2016, 04:56:27 am
« on: November 05, 2014, 02:04:56 am »
I have a Wells Gardner d9200 that has a bow on the bottom of the screen... Its like pincushion but vertical and only on the bottom of the screen... Anyone out there have any experience with these monitors? I was told it may be a tube issue... (I'm hoping its not)...Will a recap help? If so, which caps should I go for? Thanks in advance...
grantspain
Re: D9200 screen bowing issues - HELP
« Reply #1 on: November 06, 2014, 06:27:37 pm »
you should be able to adjust that out in the extended menu
hold down and select to access factory settings
deuceduzit
« Reply #2 on: November 07, 2014, 05:13:19 pm »
I tried that but there isn't anything I can adjust? What am I looking for? There is pincusion for the left and right side but nothing for top and bottom curve...
grantspain
« Reply #3 on: November 07, 2014, 07:13:47 pm »
post a photo of the problem
galaxian77
  • Last login:November 05, 2025, 03:03:26 am
  • Groovyarcade fan !
    • Arcade Sunday (YouTube)
« Reply #4 on: November 12, 2014, 12:54:53 am »
I know this post is old, but I'm sure the problem will be seen for generations to come. Is it anything like this picture ?
https://lh6.googleusercontent.com/-HYFaexbpdRI/VGJW-3HIYWI/AAAAAAAAD_0/p4SISX6gNt0/w604-h340-no/20141111_164730.jpg
Check out my home Arcade YouTube channel: https://www.youtube.com/channel/UCLKl6BrSjDsvCHIL2Blql-A
Still loving the classics, 30+ years later! 5 dedicated MAME cabinets: GroovyArcade, some Arduinos, real CRTs, ATI VGA cards, and some crazy hacks... Love it.
deuceduzit
« Reply #5 on: November 19, 2014, 11:27:36 pm »
Here's a picture of the problem... Any help would greatly be appreciated.
deuceduzit
« Reply #6 on: November 19, 2014, 11:28:48 pm »
Another pic.
ed12
« Reply #7 on: November 19, 2014, 11:43:33 pm »
nope that is yoke....it has shifted for the normal reason's
ed
deuceduzit
« Reply #8 on: November 19, 2014, 11:47:54 pm »
So... How do i fix the problem? I think my d9200 has a non removable yoke... Its bonded to the tube.
ed12
« Reply #9 on: November 20, 2014, 12:05:39 am »
yes it should be bounded
there is a small test u can do
CATUION u will be around some high volt's
were glove's here,with it running
try to shift the youke up and down,see if it move's ? if it dose it means
the glue has come free,this is normal in them unit's,and is fixable,
as a rule this turn's into a purity problem first,then as heat/time get to the glue
it becomes horz/vert linearity problems
the latter is what u have in the bowing
once u have done the test i spoke of get back to me,i will explain the fix
if it is the problem ?.
ed
deuceduzit
« Reply #10 on: November 20, 2014, 12:57:54 am »
Cool. I'll try that this weekend. Thank you for your help :)
ed
deuceduzit
« Reply #11 on: November 24, 2014, 02:49:07 am »
So I tried turning the yoke left and right and it won't budge.... No change... However I did notice I am missing what looks like a maget. First picture shows the grey ring with a rectangular magnet on top, 2nd pic shows the bottom missing magnet. I woner if getting a magnet in there will solve my problem.
Ken Layton
  • Guru
  • Technician
« Reply #12 on: November 24, 2014, 12:09:12 pm »
This thread may help:
http://forums.arcade-museum.com/showthread.php?t=185603
These monitors had crappy capacitors installed at the factory and it is strongly advised to install a full capkit. Zanen Electronics sells kit # 260 for this model and it contains 64 electrolytic capacitors for just $9.95
