Author Topic: Vigolix bartop - M.Y. Arcade -- DONE!!! 2/6/2015  (Read 40726 times)
jaharr01
Re: Has anyone built 2 Vigolix? I'd like to build a vert and horizontal
« Reply #40 on: October 29, 2014, 08:30:15 pm »
I was thinking something more like this for the bartop profile
OMG JDfan, thats fugly. So what are you powering it with, pi?
Jay
jaharr01
« Reply #41 on: October 29, 2014, 08:37:56 pm »
"Sponge....once you learn how to do that right you will never sand drywall again...
My build has been derailed for a week while I move a bathroom wall, drywall, paint, new floor, etc so I'm heading home for drywall work too."
I tried I could never get it right. I watched I guy drywall my addition,he would come everyday put a coat on and leave, never sanded his previous coats. Then after about 5 coats he sanded for about an hour and he was done. I put it on sand it off put it back on again.That last bartop looks much better.
Generic Eric
« Reply #42 on: October 29, 2014, 08:48:38 pm »
I like that you posted this cutsheet and sketchup file.
BorgDog
« Reply #43 on: October 29, 2014, 08:57:39 pm »
Don't forget the kerf. I did once.
Edit: In fact, Eric was the one who reminded me.
yeah, i chose to ignore the kerf for this as I wasn't worried about getting anything exact and figure 1/8" less on most of the pieces wouldn't matter much.  I was just thinking it could also be made wider if needed just by extending the control panel and the 2 cp brace pieces down into the "parts?" area.  the monitor support will run short at some point but a couple inches wider is probably doable.. hmmm maybe I can make the monitor rotate... must measure the diagonal and see what it takes, the monitor stand I have has a pivot built in.
Here is the actual sketchup file that has both in it if someone wanted to make it all work right.  I did make a couple errors in drawing it so it would need a little work.
« Last Edit: October 29, 2014, 08:59:46 pm by BorgDog »
My Projects:
BorgDog
« Reply #44 on: October 29, 2014, 09:04:24 pm »
I'm not sure, but is that a nod of approval from the originator Vigo the Carpathian?   :cheers:
My Projects:
« Reply #45 on: October 30, 2014, 12:05:00 am »
It is!  It seems to have the makings of  stylish and easy bar top. :) I'd like to see it cut out to get the details sorted.  If I am to really nitpick, it seems to be a little tougher of a cut for between the side panels than the standard vigolix, but in the scheme of things it is still a very easy side to cut even when compared to something basic like a weecade. It is also hard to say if it would need a front panel below the control panel, but even a small plank would solve that.
It looks really good! Looks like an awesome cutting diagram. :cheers:
jaharr01
« Reply #46 on: October 30, 2014, 02:37:58 am »
I will be impressed if someone could stuff a CRT in one of those things
BorgDog
« Reply #47 on: October 30, 2014, 08:57:21 am »
 :laugh2:  yeah, that would be impressive
and Vigo I agree that it needs at least 1 more panel, and to be honest if I actually build it (ran out of time last night to play) I would box in the bottom entirely for somewhere to stuff a computer and such, as well as close in the bottom of the control panel just to cover up the wires.  So realistically to actually make a full functional one from a 2'x2' panel I think it would need to be scaled down to maybe 15" monitor size.
My Projects:
« Reply #48 on: October 30, 2014, 09:26:26 am »
Hmm, I have two 15" color CRT VGA monitors in my garage...
nitrogen_widget
« Reply #49 on: October 30, 2014, 09:38:18 am »
found a 14" toshiba CRT TV with component in for $7 at the thrift store.
I was tempted to get it just because of the component inputs....
maybe i'll snag it.
  • Last login:Today at 12:33:00 am
« Reply #50 on: October 30, 2014, 09:57:38 am »
*sigh*
At least it's not another godforsaken weecade.
  • Last login:Today at 03:35:47 am
« Reply #51 on: October 30, 2014, 10:37:48 am »
*sigh*
Yeah, I suggest the Vigolix Bartop stuff get split off from Eric's original request. It should probably have it's own thread.
Generic Eric
« Reply #52 on: October 30, 2014, 11:15:10 am »
*sigh*
Why not.  Just don't call it weelix.
BorgDog
« Reply #53 on: October 30, 2014, 11:52:20 am »
 :applaud:  :notworthy:  :cheers:  :laugh2:  :lol:
Of course now that is all that it will ever be referred to as at least in my head anyway.
My Projects:
Yenome
  • Last login:November 14, 2025, 04:36:28 am
  • Punch a fish. Make a wish
Re: Vigolix bartop?
« Reply #54 on: October 31, 2014, 11:22:05 am »
i vote wilix for the name
rawbe
  • Last login:June 17, 2025, 05:54:46 pm
Re: Vigolix bartop?
« Reply #55 on: October 31, 2014, 11:51:28 am »
What you talking about Wilix?
BorgDog
Re: Vigolix bartop?
« Reply #56 on: October 31, 2014, 11:58:15 am »
Played around with design some more, still have not found time to get out in the shop and actually cut some wood but playing in sketchup is fun as well (especially at work).
I made this cut sheet with a smaller overall design, but still will fit my 17" lcd monitor.  there is actually enough wood to make the entire design from a 2'x2' sheet.  I plan on doing this with 1/2" plywood and using some of the extras to add diagonal braces where needed.  Pocket screws for attachment.  I also thought this morning of making it with a square opening and mounting the monitor in a bezel/frame with french cleats so I could just easily lift it off from the front and rotate between horizontal and vertical mode.  I haven't drawn it up, but I don't think I could make it work with only a 2'x2' piece as I would want the bezel to be 1 piece around the front.
And I'm not sure what kind of computer would fit in here, a raspberry pi for sure, a nuc would be awesome but expensive.  An old crap netbook would probably work fine for mame and also fit the space... hmmm need to think about this part.
My Projects:
Re: Vigolix bartop?
« Reply #57 on: October 31, 2014, 12:01:07 pm »
I like the lower profile Control Panel. It gives it a look a stability.
Re: Vigolix bartop?
« Reply #58 on: October 31, 2014, 12:20:08 pm »
So we've devolved from the laptop wrapped in cardboard aesthetic of the weecade, into a laptop stand?
 :dizzy:
Yenome
Re: Vigolix bartop?
« Reply #59 on: October 31, 2014, 01:27:48 pm »
ah ha i see what you did there.
BorgDog
Re: Vigolix bartop?
« Reply #60 on: November 28, 2014, 07:34:25 pm »
To revive..... a little preview, project thread coming.. maybe, this is the only progress pic I've taken.  Sitting next to my mini-pin cab on my half desk (hmmm sensing a trend here).  the 17" monitor sitting behind it is what's going into it, going to be attached to the piece of plywood in the monitor spot, with hole cut out of course.  display will pop out the front to manually rotate for horizontal or vertical mode, opening/plywood mount is square.
My Projects:
Yenome
Re: Vigolix bartop?
« Reply #61 on: December 01, 2014, 12:51:48 pm »
Im probably going to build one of these. tho i was thinking of making it wider for two player panel
nitrogen_widget
Re: Vigolix bartop?
« Reply #62 on: December 02, 2014, 12:30:01 pm »
Going to try & make one of these on my vacation over christmas.
I'm building a 4-way vert classic with a 2 1/2" trackball and a 15" 4:3 LCD.
I'm hoping the 15" panel doesn't look too narrow for the control panel otherwise I do have a 17" 4:3 LCD I can use.
grippie
  • Last login:February 28, 2025, 10:00:46 am
  • Genesis Does
    • Optimus Meatron
Re: Vigolix bartop?
« Reply #63 on: December 02, 2014, 04:26:20 pm »
Found you some artwork inspiration for this bad boy.  :laugh2:
AzureKnight
Re: Vigolix bartop?
« Reply #64 on: December 03, 2014, 09:24:19 am »
I kept seeing Dynomutt myself.
All kidding aside that is looking nice so far, it is a really cool idea to do a small conversion like this.  I may be doing one of these as a gift at some point.
Re: Vigolix bartop?
« Reply #65 on: December 03, 2014, 09:28:30 am »
Does someone have a plan for the top area? I'm not digging the "ears".
BorgDog
Re: Vigolix bartop?
« Reply #66 on: December 03, 2014, 12:19:12 pm »
Was thinking of doing a small marquee like DeLuSioNals Invader Vigolix http://forum.arcadecontrols.com/index.php/topic,141778.0.html but that little top part is at most 3" tall so I'm not sure how well it would work.  Had I not rounded it off it might have worked better.
Besides the ears remind me of my dog.
My Projects:
Locke141
  • Never grow up.
« Reply #67 on: December 03, 2014, 02:49:35 pm »
I have a 60 watt CNC laser at work with a 4' by 2' bed. I might give this a go after work one day next week. It would probably look good in plexi with edge lit graphics.
« Last Edit: December 03, 2014, 02:57:56 pm by Locke141 »
BorgDog
« Reply #68 on: December 04, 2014, 11:44:44 am »
That's cheating!  :cheers:  Heck compared to some of these guys working with such basic tools I feel I'm cheating using my table saw.
So I did a little more work on my dog eared vigolix-bartop (NOT a weelix).  borrowing from my mini-pin build (in case anyone interested http://www.vpforums.org/index.php?showtopic=29303&hl=pindog), I borrowed a poster/saying from one of my other favorite sites Garage Journal and 44 Bikes who posted the original "bike" version.  If you are into hand built bicycles or just seeing how they are made, or really cool shops, check out Kristofer Henry's thread http://www.garagejournal.com/forum/showthread.php?t=112578.The guy is simply amazing.
While I watch the paint dry I'm working on my Mala artwork and maybe a CPO and really iffy a marquee for the top.. more on those later.
Here is a pic from this morning after last nights painting session.
My Projects:
BorgDog
Re: Vigolix bartop?
« Reply #69 on: December 04, 2014, 12:57:40 pm »
Pulling and paraphrasing from a control panel question I posted elsewhere, this project is titled Dan's Misspent Youth Arcade, or the short version M.Y. Arcade.  Being a teenager in the late 70s, and living in a small rural town I had a limited selection of game exposure being mostly at the mercy of the small arcade in the bowling alley, and I am planning this cabinet to play those games I most fondly remember stuffing quarters into.  Far and away the two biggest eaters of my meager money supply were Asteroids and Space Invaders.  Just those 2 brought me to my first dilemma, vertical or horizontal   :-\  After those came Space Zap, Missile Command, Defender, Frogger, Galaxian, Centipede, Zaxxon, Pacman and Donkey Kong.  So again a mix of vertical and horizontal.  Of course it will likely run a bunch more mame games, but getting those on will be my goal.
In the end I decided to go with just 4-way joystick (Zippy from GGG, so could do 8-way if I wanted), buttons in a mostly Asteroids with Space Zap arrangement, and a U-Trak.  Oh, and to solve the orientation dilemma I decided to build it with a manually rotate-able monitor that simply pulls out the front to move.
Here is an overview shot from Sketchup of M.Y. Arcade
Here is a shot of the control panel.
Attached is the sketchup file that is pretty close to how I built it.
« Last Edit: December 16, 2014, 11:30:14 am by BorgDog »
My Projects:
RetroGreg
Re: Vigolix bartop?
« Reply #70 on: December 05, 2014, 09:53:57 pm »
I like it. I'm eager to see how the rotation will work.
BorgDog
Re: Vigolix bartop?
« Reply #71 on: December 07, 2014, 10:58:09 pm »
Was gone for most of the weekend, but started putting all the parts back in, still need to wire it all up and mount the computer and such, put the plexy front on, make a very skinny not lit marquee...
Sorry for the crappy cell pics, but here it is in horizontal and vertical modes.
My Projects:
Generic Eric
Re: Vigolix bartop?
« Reply #72 on: December 07, 2014, 11:46:08 pm »
I too, would also like to see how the rotation will work.
BorgDog
Re: Vigolix bartop?
« Reply #73 on: December 08, 2014, 07:48:08 pm »
It is very very low tech.  grab the bezel with your hands, pull it and the monitor out of the slot it is sitting in, turn sideways, put back in slot.  It simply leans up against the crosspiece in the back.  I am working on a way to lock it in place with a butterfly catch for transport.
My Projects:
BorgDog
Re: Vigolix bartop?
« Reply #74 on: December 10, 2014, 10:05:51 pm »
Getting started on the guts.. who's idea was it to put so damn many buttons in this little space?  Waiting for some more connectors to arrive tomorrow.  Posting a pic because I actually thought to take one  :blank:
My Projects:
BorgDog
Re: Vigolix bartop?
« Reply #75 on: December 10, 2014, 11:00:59 pm »
Also making progress on my simple design for a thin, non-lit, marquee and control panel.  Attached are low rez versions, comment/suggestions welcome.  not planning on doing any other graphics on the cab.  I am doing a simple MaLa theme to go along with Spaceman Spiff/Stupendous Man motif.
« Last Edit: December 10, 2014, 11:08:18 pm by BorgDog »
My Projects:
Rockhart
  • Last login:August 11, 2017, 02:15:04 pm
  • Game on!
Re: Vigolix bartop?
« Reply #76 on: December 11, 2014, 01:04:26 am »
Awesome choice going with Spaceman Spiff! I'd suggest adding a background to the control panel though, as the black is a little bland. Maybe one of the Mars backgrounds?
Part of the appeal of Calvin and Hobbes is the fantastic art. You should use more of it!! :)
BorgDog
Re: Vigolix bartop?
« Reply #77 on: December 11, 2014, 01:15:40 pm »
Thanks.  I've played around with a couple different backgrounds, including the one you posted, but I kinda prefer the plain look.
My Projects:
Re: Vigolix bartop?
« Reply #78 on: December 11, 2014, 02:05:14 pm »
I dig your Space Zap controls!
Rockhart
  • Game on!
Re: Vigolix bartop?
« Reply #79 on: December 12, 2014, 12:20:15 am »
You should pick what you like best, but I think both of those options look really cool.  :applaud:
