Author Topic: Vigolix bartop - M.Y. Arcade -- DONE!!! 2/6/2015  (Read 41903 times)
BorgDog
« on: October 28, 2014, 05:03:05 pm »
My solution, vigolix bar top that slips into the cabinet on the porch when I have an outdoor party & can be easily brought in at night or the winter.
I keep seeing people talk of vigolix bar tops but I have yet to see one.  Anybody actually made one yet?   :dunno
EDIT:  For those just seeing this, this thread started out as part of a discussion about building both horizontal and vertical vigolix cabs (http://forum.arcadecontrols.com/index.php/topic,142071.0.html), that digressed into a vigolix bartop design discussion which was subsequently split into its own discussion on the Main page, then when I added a pic of my actual build of my Vigolix bartop DeLuSioNal moved it over to the project announcement pages, and now since my name ended up on top of the thread I am using as my mini build thread.  The actual build part comes in page 2 of this thread somewhere.  Just thought I'd put this here so it made a little more sense coming in the middle of the discussion.  I'll probably add my finished pics to this post once I'm done as well.
Here is a preview of the completed project.
« Last Edit: February 06, 2015, 10:45:19 pm by BorgDog »
My Projects:
Generic Eric
Re: Has anyone built 2 Vigolix? I'd like to build a vert and horizontal
« Reply #1 on: October 28, 2014, 05:24:58 pm »
Wouldn't a Vigolix bartop just be a right triangle?  >:D
Wouldn't it just be a bartop?
« Reply #2 on: October 28, 2014, 05:32:59 pm »
Shaped like a right triangle?
« Reply #3 on: October 28, 2014, 05:35:48 pm »
« Reply #4 on: October 28, 2014, 05:41:37 pm »
Here are your plans, bro.
« Reply #5 on: October 28, 2014, 05:47:42 pm »
 :dunno What, no sketchup?
« Reply #6 on: October 28, 2014, 05:51:27 pm »
Told you I got better at this!
« Last Edit: October 28, 2014, 05:56:22 pm by yotsuya »
« Reply #7 on: October 28, 2014, 06:02:31 pm »
Haha! Nice! Faceless woman looks like she is snubbing them.
Louis Tully
« Reply #8 on: October 28, 2014, 06:03:15 pm »
« Last Edit: February 12, 2015, 05:53:11 pm by Louis Tully »
« Reply #9 on: October 28, 2014, 06:06:11 pm »
Kickin'! Glad to see you're sticking with it.  :applaud:
Although I whipped those together as a joke, I feel confident enough in my Sketchupiness that I could even tackle that. If I would have tried that two weeks ago, I would have ended up punching kittens or something.
« Reply #10 on: October 28, 2014, 06:08:02 pm »
Don't worry, you can still punch a kitten.
« Reply #11 on: October 28, 2014, 06:11:03 pm »
Naw.... they punch back....
« Reply #12 on: October 28, 2014, 06:20:43 pm »
« Reply #13 on: October 28, 2014, 07:33:41 pm »
The bartops don't look that special but I'm impressed with the hand-drawn women.    :cheers:
 >:D
nitrogen_widget
« Reply #14 on: October 28, 2014, 08:29:58 pm »
hahahahahaaa errmmmm......I guess so. :)
Gonna have to trow some wood in the table saw & see if a triangle with a flat vertex instead of a point looks less right.
fyi, I renovated my house & tend to build things on the fly vs. plan them out.
Every room of my house has trim cut differently as I figured out different ways to do things as I learned along the way.
surprisingly it all looks fairly good.
I think I have some 1/4 mdf in the basement.
BorgDog
« Reply #15 on: October 28, 2014, 10:55:47 pm »
See not bad, I'm thinking more like this though.
My Projects:
« Reply #16 on: October 28, 2014, 11:09:10 pm »
I **do** like that one.
JDFan
« Reply #17 on: October 28, 2014, 11:28:34 pm »
I was thinking something more like this for the bartop profile
« Reply #18 on: October 28, 2014, 11:49:12 pm »
I dunno, looks like it would tip forward most of the time.
JDFan
« Reply #19 on: October 29, 2014, 12:30:18 am »
True - could always add some to the front end to stabilize.
BorgDog
« Reply #20 on: October 29, 2014, 09:11:06 am »
In keeping with a pointy theme I'd do it more like this.
My Projects:
Generic Eric
« Reply #21 on: October 29, 2014, 09:14:42 am »
Can it be built from a single sheet?  2'x2'
jdbailey1206
« Reply #22 on: October 29, 2014, 09:48:23 am »
How about something like this:
« Reply #23 on: October 29, 2014, 09:59:45 am »
The whole point of this design was to make a decent looking little cab with the least amount of material.
The bartop version should have the same goal of squeezing the most out of a 2'x4' sheet.
I'd also like to see someone come up with a full size cab design that can be made from a single 4'x8' sheet.
« Last Edit: October 29, 2014, 10:02:05 am by BadMouth »
JDFan
« Reply #24 on: October 29, 2014, 10:23:44 am »
Figure the 2 side pieces can be laid out on a 24"x14" piece - which would leave 10"x24" for the rest (plus the material cut out of the center and back of the sides -- So should be doable depending on the size monitor you want to fit in there (Should be room for maybe a 15" 4:3)  :dunno
« Reply #25 on: October 29, 2014, 10:25:14 am »
Vigo made a driving Vigolix, remember.
BorgDog
« Reply #26 on: October 29, 2014, 11:34:00 am »
hmmm, I'm sure I have a piece of scrap at least that size, and this sounds a lot more fun than the tape and mud project I'm supposed to do when I get home from work  :applaud:
My Projects:
« Reply #27 on: October 29, 2014, 12:18:04 pm »
I love doing tape and mud projects, but the sanding is a ---smurfette---.
AzureKnight
« Reply #28 on: October 29, 2014, 01:41:37 pm »
Sponge....once you learn how to do that right you will never sand drywall again...
My build has been derailed for a week while I move a bathroom wall, drywall, paint, new floor, etc so I'm heading home for drywall work too.
Yenome
  • Last login:November 14, 2025, 04:36:28 am
  • Punch a fish. Make a wish
« Reply #29 on: October 29, 2014, 01:48:43 pm »
Hmm when i get home i got a 2x4 mdf sheet at home im gonna see if i can draw it up to at least get to sides CP top and front and one piece for the monitor to mount too could use black contruction paper for a bezel to cover monitor. and mount pc board to back of monitor mount. wish i wasnt at work to try this :(
« Reply #30 on: October 29, 2014, 02:14:59 pm »
I just completed one bathroom project and will be finished a second shortly. When are you sponging? After it's dry?
« Reply #31 on: October 29, 2014, 02:24:16 pm »
you use a wet sponge to remove the excess joint compound instead of sanding it off.
AzureKnight
« Reply #32 on: October 29, 2014, 02:28:28 pm »
Yes, you have to be careful and do a relatively clean job of mudding with the putty knife.  Then let it dry, when you are ready to sand get a damp sponge and lightly feather away at the area.  You have to be careful not to use too much water.  Sometimes you have to let it dry again and do a second round of damp sponging.
Once you get good at it, I think it takes half the time and there is no drywall dust blowing all over the entire house (city block?  that stuff is evil).
I'm sure you can find many other videos but here is one:
« Reply #33 on: October 29, 2014, 02:31:58 pm »
I'll have to test that out when I finish the other bathroom.  :cheers:
BorgDog
« Reply #34 on: October 29, 2014, 06:10:09 pm »
Enough with the mud talk.  I had a little time to play at work today and came up with a cut plan and pieced together a model from it.  I think I would still want to add more to make a finished cab, but this gets darn close.  Thats also quickie model of the 17" monitor I plan on using in my bartop, fits just right.  Control panel could easily be moved lower depending on need.
My Projects:
Yenome
« Reply #35 on: October 29, 2014, 06:20:31 pm »
Nice job borgdog i like it. personally i was thinking traditional bar top but this is a vigolix bartop so yours makes sense
« Reply #36 on: October 29, 2014, 06:21:13 pm »
« Reply #37 on: October 29, 2014, 06:46:11 pm »
So a 4' x 2' would easily have enough material to finish it off. Good to know.
horizon
  • Last login:November 09, 2015, 05:58:48 pm
  • They've gone plaid!
« Reply #38 on: October 29, 2014, 07:17:22 pm »
Just forwarded this to a buddy who is doing a vigolix soonish.  Bartop might be ideal for his living space.
You guys rock.
Louis Tully
« Reply #39 on: October 29, 2014, 07:25:09 pm »
« Last Edit: February 12, 2015, 05:53:26 pm by Louis Tully »
