Author Topic: Grommet for hole in cabinet  (Read 1933 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« on: October 19, 2014, 09:00:47 am »
Just realized I posted an earlier thread in a wrong forum  :embarassed:
Anyway, I am trying to find the best way to feed my light gun cable into my cab, and was wondering what would look best. I'm hoping to make it look neater than just feeding the cable through a hole....was thinking if there is something like a grommet or something that I can line the hole with so that it looks nice and also will be smooth for the cable to be fed through when not in use....rather than having excess cable on the outside.  I was thinking of making a retractable USB cable to the gun but that would involve dismantling the gun and having to wire it properly...too much effort.
Thoughts?
Re: Grommet for hole in cabinet
« Reply #1 on: October 19, 2014, 09:09:18 am »
I Googled "rubber cable boot" and got a number of interesting possibilities that would look better than just a "cable through a hole".
Depending on what your cab looks like, you might also consider a small piece of Vinyl, sew it into a boot (like a shift boot in a car), and tuck it/staple in place.
Louis Tully
« Reply #2 on: October 19, 2014, 09:16:55 am »
« Last Edit: February 12, 2015, 05:48:31 pm by Louis Tully »
chopperthedog
  • Last login:Yesterday at 07:01:40 pm
« Reply #3 on: October 19, 2014, 01:11:56 pm »
A button with the plunger removed and the bottom cut off works great.
good day.
« Last Edit: October 19, 2014, 01:53:14 pm by drventure »
mgb
  • North East, US
« Reply #5 on: October 19, 2014, 03:22:21 pm »
good day.
The button bezel works great. I used the same method for bass ports on my cab
IAmDotorg
  • Last login:April 27, 2015, 03:05:37 pm
« Reply #6 on: October 20, 2014, 08:12:47 am »
I used the SwitchCraft USB and HDMI ports (like the one above) on my cab.
If its a continuous cable, one option is to get a metal disk, like 1.5" in diameter or something drill a hole in the middle of it, paint or powdercoat it to match the cab, and put a rubber grommet in it.
I built a car from the ground up and did quite a few plates like that where I needed a wire passthrough that looked good. (In my case, they were polished aluminum.)
