Hi again, I bought the adaptor and have been trying to make it work without success.
I've installed the last version of CRT Emudriver (
http://geedorah.com/eiusdemmodi/forum/misc.php?action=redirect&pid=1009&to=https://drive.google.com/open?id=1HYtmxr_Bla3RtVww4lXDVbe7plvHKO2S).
When I try to enable EDID emulation on VMMaker, my TFT 31khz standard PC monitor doesn't go out of sync...
The card has three DP outputs. I've tried all of them.
I also disabled mainboard onboard GPU.
I allways get the same result:
After rebooting my PC, first time I open WMMaker it looks like this (6 Displays detected)
Two analog outputs are detected
When I enable EDID emulation the screen goes black and after 1 or 2 seconds it returns to desktop and shows this dialog
After that it returns to the WMMaker interface but this time the Displays looks like this
As you can see Displays numbers has increased. At this time if I disable EDID emulation display's numbers goes even higher
And It contunues to happen until I reboot my PC. I open WMMaker and display's numbers are set again like in the begining...
I've tried all combinations of analog outputs (0 and 1) swaping through the three DP's but can't get a 15Khz signal output...
Any suggestion??
