Author Topic: Can't get images to show up when in low resolution.  (Read 2482 times)
yatzr
  • Last login:May 17, 2021, 11:26:57 pm
« on: October 11, 2014, 02:13:47 pm »
I've got a win7 / groovymame setup with an arcade monitor where mala is being displayed at a 640x480 interlaced resolution.  Everything seems to be fine, except that I can't get images to show up at all.  I'm using a fresh install with the default layout.  I did the same thing recently on a different machine with an lcd at 1280x1024 and images showed up just fine.  I've tried messing with a lot of mala's configuration, but still haven't gotten it to work.  Is there some trick to it?
