Author Topic: Hard microswitches, tired fingers after playing.  (Read 2108 times)
nordemoniac
  • Weee! Hahaha...
« on: October 08, 2014, 04:11:29 am »
I have a couple of sets with joysticks and buttons, and one of them has REALLY hard microswitches. I would like to order new ones to replace them, so I've ordered one here and one there to compare them, but sometimes I feel like I get them at random. I want all switches to be the same, and I want them to be soft. One of the HAPP sets I ordered had 3 hard ones, two of them went to the player buttons, the last to a button which won't be used much - so that was OK.
Take a look at these pictures:
I did a test like this on a scale. I measured multiple times, and wrote down the highest number I could get before the button "clicked" into the casing.
I was shocked when I saw that the switch required no less than 230 grams of pressure to activate!
Then I did the same test on my HAPP switch:
Why?!
The hard one uses a spring to hold the tension for the switch, when you push it hard enough down, it snaps down, and activates.
The HAPP one uses a leaf spring method, and requires almost no pressure to activate, similar of a typical keyboard key.
The 230g switch is as hard as you would expect a door opener etc. to be, not a button on a gaming device.
These 230g ones belong to a set I bought on an auction, blue LED lit. I thought the LED lit buttons and joysticks was REALLY cool and awesome, but atm. I'm not that into LEDs :P I even bought the LED drive as well...
Will have to make a cool build with it sometime (active buttons lit on emulators etc).
Anyways, back to topic - Where do you get your microswitches? I'm talking $1 ones or less...
« Last Edit: October 08, 2014, 04:24:17 am by nordemoniac »
Louis Tully
Re: Hard microswitches, tired fingers after playing.
« Reply #1 on: October 08, 2014, 04:37:02 am »
« Last Edit: February 12, 2015, 05:46:46 pm by Louis Tully »
nordemoniac
  • Weee! Hahaha...
« Reply #2 on: October 08, 2014, 06:10:47 am »
Awesome! Guess I'll buy 100 of these :)
« Reply #3 on: October 08, 2014, 09:23:03 am »
I should also suggest the true leaf pro buttons/switches.  They are pretty great.
  • Last login:July 11, 2025, 09:17:44 am
« Reply #4 on: October 08, 2014, 11:21:10 am »
I've tried these as well and they're great too (although not the price you were looking for).
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=92&products_id=309
They will snap right into the standard button even though they look slightly different than the typical microswitch.
D
  • Last login:June 25, 2025, 03:09:16 pm
« Reply #5 on: October 08, 2014, 02:42:13 pm »
Op has a good post on the importance of microswitch weight.  :applaud:
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
« Reply #6 on: October 09, 2014, 09:46:38 pm »
I use the microleafs for my main 6 buttons.  Just a bit more pressure needed to actuate these from a resting finger.  I want to replace the ones in my Blackhawk spinner with something less stiff.  Any ideas?
WindDrake
  • Last login:December 03, 2020, 09:49:05 pm
  • Electrical Engineer
« Reply #7 on: October 09, 2014, 10:23:19 pm »
I was always a fan of the classic Cherry D44X, even though they are a little harder to get nowadays. 75g was just heavy enough to give me the feedback I wanted without all the finger fatigue.
Generic Eric
« Reply #8 on: October 09, 2014, 11:00:40 pm »
I heard it myself bot, it was very well worded.
nordemoniac
  • Weee! Hahaha...
« Reply #9 on: October 10, 2014, 03:44:00 am »
Thanks dude!  :cheers:
LOL :P
  • Last login:August 19, 2025, 03:10:32 pm
« Reply #10 on: October 10, 2014, 10:04:22 am »
Am I the only one who mashes switches until they bottom out anyway?
« Reply #11 on: October 11, 2014, 11:13:02 am »
Nope, its the only way to play  :applaud:
RandyT
  • Last login:August 22, 2025, 02:12:07 pm
    • GroovyGameGear.com
« Reply #12 on: October 11, 2014, 11:50:24 am »
So it was you two who messed up all the leaf switch buttons back in the eighties.  :angry:
j/k
