Author Topic: Ultimarc GoldLeaf buttons dimensions  (Read 2775 times)
Yvan256
    • Yvan256
« on: September 22, 2014, 03:21:30 pm »
Is there anyone who has the dimensions of the Ultimarc GoldLeaf buttons?
  • Last login:Today at 03:40:28 am
Re: Ultimarc GoldLeaf buttons dimensions
« Reply #1 on: September 22, 2014, 03:29:46 pm »
* Grabs calipers and a Goldleaf.
1.315" from bottom of bezel to bottom of barrel.
1.090" outer diameter of threads.
1.31" bezel diameter.
0.35" from bottom of bezel to top of plunger.
Any other measurements you need?
Yvan256
    • Yvan256
« Reply #2 on: September 22, 2014, 03:36:04 pm »
33.401mm from bottom of bezel to bottom of barrel.
27.686mm outer diameter of threads.
33.274mm bezel diameter.
8.89mm from bottom of bezel to top of plunger.
22.6568mm plunger diameter.
3.7592mm bezel height.
Thanks Scott!
edit: added plunger diameter and bezel height.
« Last Edit: September 22, 2014, 03:44:50 pm by Yvan256 »
« Reply #3 on: September 22, 2014, 03:41:52 pm »
I guess the only things missing are the plunger diameter and the bezel height.
0.892" plunger diameter.
0.148" bezel height.   ;D
Yvan256
    • Yvan256
« Reply #4 on: September 22, 2014, 03:47:18 pm »
Thanks again!
And now, I need to find which joystick has the lowest installation depth... Will it be a Sanwa or a Seimitsu?
« Reply #5 on: September 22, 2014, 04:03:54 pm »
Which Sanwa stick and which Seimitsu stick?  :dunno
(Sorry, don't have any here to measure, just Happ Supers, some Zippyys, and a Happ Rotary -- the rotary is definitely NOT the stick you're looking for.  :lol)
Yvan256
    • Yvan256
« Reply #6 on: September 22, 2014, 04:09:19 pm »
I guess it would be between the usual Sanwa JLF-TP-8YT or the Seimitsu LS-32 or LS-55.
But here's what it looks like so far, with the Sanwa JLF top-mounted and the Ultimarc Goldleaf. The space between the CP and the buttons is a placeholder for a 1/8" plexi/lexan to cover the CP artwork (if any).
« Last Edit: September 22, 2014, 04:46:28 pm by Yvan256 »
