Author Topic: Paint: semi gloss, gloss or flat  (Read 3711 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
« on: September 19, 2014, 09:25:23 pm »
Just curious what the consensus is for the shine of paint for a cab that would look best.
  • Last login:Yesterday at 11:23:23 pm
Re: Paint: semi gloss, gloss or flat
« Reply #1 on: September 19, 2014, 09:31:18 pm »
Satin acrylic enamel
mgb
  • North East, US
« Reply #2 on: September 20, 2014, 07:38:07 am »
This, without a doubt.
Louis Tully
« Reply #3 on: September 20, 2014, 08:58:00 am »
« Last Edit: February 12, 2015, 05:33:28 pm by Louis Tully »
Richardgregory
« Reply #4 on: September 20, 2014, 09:50:03 am »
These are spray can paints?
It's more challenging than paint using a roller no?
Louis Tully
« Reply #5 on: September 20, 2014, 10:16:41 am »
« Last Edit: February 12, 2015, 05:33:35 pm by Louis Tully »
mgb
  • North East, US
« Reply #6 on: September 20, 2014, 11:41:43 am »
I would use a roller or Wagner type sprayer
« Reply #7 on: September 20, 2014, 11:52:36 am »
I use the Wooster rollers from Home Depot. Can't go wrong.
Richardgregory
« Reply #8 on: September 21, 2014, 06:08:48 pm »
I'm going to get some good rollers for sure....I should be using high density foam ones no?
On a side note:  my friend who has stripped an old cab as well has white melamine/laminate on top of chip wood....it's smooth and even after a slight sanding using 150 grit it still feels smooth. I hope the primer will stick to it.
« Reply #9 on: September 21, 2014, 06:26:25 pm »
Did you buy that primer for plastics???
Richardgregory
« Reply #10 on: September 21, 2014, 08:09:58 pm »
Yup....primer was bought.  It'll be interesting to see how well it adheres to the surface
« Reply #11 on: September 21, 2014, 08:27:12 pm »
You should be fine. Don't rush it. Spray it on, let it dry, sand out any bumps, and you should be golden.
« Reply #12 on: September 21, 2014, 09:36:32 pm »
+1 - Satin all the way.  I've tried gloss but it dries way too shiny for my taste.  Satin is perfect.  I also used Rustoleum's brand (oil based) applied with a roller.  You can use a foam brush for areas where the roller will not fit first, then finish up with the foam roller.
P.S. - I've tried latex water based paint and hated it.  The only advantage (to me) is that it cleans up easier with soap and water.  But it took me many coats of latex based paint to get it looking "perfect".  Oil based for me coated better.
DeLuSioNaL29
jdbailey1206
« Reply #13 on: September 22, 2014, 09:51:59 am »
I had some troubles with oil based paints.  It could be I had my cab too close to my wood burning stove when I was painting it and the oil began to seep from the paint.  Oh well.
Water based latex for me seems to go on easier with less sanding.  I've used all the brands listed here and all of them work well.  On my FF Jr. cab I used gloss, semi gloss, and flat but the outside was satin and it left a great finish.
I would also recommend using a foam roller.  Using a wool based roller tends to leave behind little clumps of material that you have to sand away when dry.
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
« Reply #14 on: September 22, 2014, 10:40:18 am »
the best and easiest finish for me is rustoleum satin black. Its available at home depot or lowes.
i thin it with acetone or laquer and spray it with a harbor freight touch up gun. lays down nice and flat and dries quick. no need to primer on new clean wood.
this is the gun that works best.
http://www.harborfreight.com/adjustable-detail-spray-gun-92126.html
« Reply #15 on: September 22, 2014, 05:12:19 pm »
This is good info.  I've never done a true cabinet repaint before and I have several coming up.  First up is a Pole Position that I'm probably going to just paint white and leave the artwork for a later time when I have the cash to blow on it.
jdbailey1206
« Reply #16 on: September 22, 2014, 05:41:42 pm »
Ive personally never used a gun though I want to.  Using the foam roller leaves a great finished texture.
« Reply #17 on: September 22, 2014, 05:57:33 pm »
Same here.
« Reply #18 on: September 22, 2014, 06:30:20 pm »
+1 although I'd love to try it one day.  It's a bit expensive though since a compressor is needed no?
I've also wanted to try black laminate as well.
D
mgb
  • North East, US
« Reply #19 on: September 22, 2014, 06:58:46 pm »
D
I know laminating costs more but I would never go with paint again.
Laminate is the best.
Unless its marbled
jdbailey1206
« Reply #20 on: September 22, 2014, 07:40:13 pm »
Quote from: mgb link=topic=141462.msg1464681#msg1464681 date
Unless its marbled
Or has lightning bolts... ;D
Saneless
  • Last login:September 19, 2015, 12:29:26 pm
« Reply #21 on: September 22, 2014, 07:44:11 pm »
I have a paint gun. Figured I'd try it for at least the first coat. Seemed to do fine on our fence
Richardgregory
« Reply #22 on: September 22, 2014, 08:28:58 pm »
I agree....if I was to do a new build I would use  black laminate that's already glued on....my local lumber shop has boards like that but are not MDF.
Richardgregory
« Reply #23 on: September 22, 2014, 08:29:57 pm »
So it has a bit of sheen/gloss correct?
« Reply #24 on: September 22, 2014, 08:41:44 pm »
Yes, but not super shiny or fingerprint attracty
mgb
  • North East, US
« Reply #25 on: September 22, 2014, 09:02:48 pm »
I'd say its got a very similar sheen to black laminate or the black vinyl that would be on a comercial arcade cab
