Author Topic: WG 1901?, HV Shutdown  (Read 2451 times)
kardenm
  • Last login:June 13, 2019, 09:14:35 am
« on: September 17, 2014, 09:16:45 am »
Working on a monitor I think is a WG. Printed on board is MTG-2901 MA REV-01 and WG 1901.
When I turn power on I hear HV come on but It immediately fades out or shuts down. Result is no picture and no HV.
I did replace the HOT but result is the same.
Where else should I start to look for this problem?  Help and advice greatly appreciated!
In theory, there is no difference between theory and practice, but in practice.....there is!!
kardenm
Re: WG 1901?, HV Shutdown
« Reply #1 on: September 20, 2014, 09:44:43 am »
Anyone??
grantspain
« Reply #2 on: September 20, 2014, 11:22:15 am »
the mtg-2901 is a tovis monitor,probably rebranded as vision pro
never heard of a wg 1901
do you have a photo of the chassis?
kardenm
« Reply #3 on: September 21, 2014, 03:14:10 pm »
No but I'll get one tomorrow.  Thanks.
kardenm
« Reply #4 on: September 23, 2014, 09:09:38 am »
Here are photos of the chassis.
« Last Edit: September 23, 2014, 09:12:18 am by kardenm »
ed12
« Reply #5 on: September 23, 2014, 10:55:32 am »
ok theres the first problem
that is not a "true" wg but rather a branded wg
i think that was made by wei
ken layton would know better
ed
kardenm
« Reply #6 on: September 23, 2014, 08:35:10 pm »
Is it possible to say which components might be causing this problem?
If I could narrow it down, I could start testing or replacing stuff.
ed12
« Reply #7 on: September 23, 2014, 08:44:08 pm »
ya it is a smps style chassic
so after the switch transformer chk your dc volt's
with ref. to that ground and not your hot ground
let's start there
ed
Ken Layton
  • Guru
  • Technician
« Reply #8 on: September 23, 2014, 11:20:43 pm »
Tovis MTG-1901 which is a.k.a. Happ Controls "Vision Pro" MTG-1901.
Service Manual:
http://arcarc.xmission.com/PDF_Monitors/Vision_Pro_%28MTG-XX01_Series_13in_and_19in_CGA%29.pdf
Manufacturer's website:
http://www.tovism.com/english/?page_id=35
ed12
« Reply #9 on: September 23, 2014, 11:48:10 pm »
thk-u ken
ed
kardenm
« Reply #10 on: September 30, 2014, 02:30:42 pm »
Yes! Thank you so much Ken and ed. I had no info on this chassis. I'll look at this Some more and post what I find.
