Hi cools,
They ran good if I forced the resolutions.
I was actually able to resolve this myself last night. To get aerofgt to run right I just needed to up the HfreqMax on range4 as aerofgt was running a little over 22Khz the max was set at. Upping it to 23500 fixed it. To fix ddonpach which was mistakenly selecting the higher ranges I upped the HfreqMax from 50 to 58 for ranges 5,6,7 in order to skip it since it's running at 57.55.
That seemed to do the trick and not negatively affect any other games so far.
------ CUSTOM PRESET -------
crt_range0 15625-15900, 50-59.96, 3.03, 6.134, 6.763, 0.067, 0.200, .532, 0, 0, 192, 248, 448, 496
crt_range1 15625-16240, 59.98-80, 3.000, 4.700, 7.700, 0.190, 0.191, 1.018, 0, 0, 192, 248, 448, 496
crt_range2 16029-17200, 50-80, 1.220, 4.728, 7.626, 0.190, 0.191, 1.018, 0, 0, 249, 256, 498, 512
crt_range3 18300-18800, 50-58, 8.300, 2.750, 9.000, 0.190, 0.191, 1.018, 0, 0, 257, 280, 514, 560
crt_range4 18448-23500, 50-80, 6.278, 2.058, 7.410, 0.799, 0.828, .876, 0, 0, 281, 320, 0, 0
crt_range5 24000-25000, 58-80, 1.163, 3.595, 1.798, 0.081, 0.162, 0.889, 0, 0, 384, 400, 0, 0
crt_range6 24000-29000, 58-80, 1.549, 2.820, 6.502, 0.225, 0.150, 2.021, 0, 0, 384, 400, 0, 0
crt_range7 30000-34000, 58-80, 0.636, 3.813, 1.906, 0.020, 0.106, 0.607, 0, 0, 448, 496, 0, 0
crt_range8 34001-38000, 50-80, 1.000, 3.200, 2.200, 0.020, 0.106, 0.607, 0, 0, 512, 600, 0, 0
