Author Topic: RGB Converter Issues  (Read 1022 times)
  • Last login:December 02, 2025, 03:23:14 pm
« on: September 09, 2014, 10:26:17 am »
So I am building a bartop, using an R-Type II pcb and LCD screen.
I picked up a Gonbes converter, like this:  http://www.ebay.com/itm/180833084570
I've had good luck with these in the past.
Now, when I hook the board up and connect to the monitor via VGA, I get a picture, but it jumps up and down vertically, enough to make it unplayable.
I also have one of these boards :  http://www.ebay.com/itm/260868532793
It outputs composite and S-video.  Now, with these signals, the picture is stable, but the bottom part of the picture is cut off (which is needed for R-Type II).
I've hooked up a JROK sync cleaner and it didn't help.
Any other ideas?
