Author Topic: ground wiring in control panel  (Read 3812 times)
RWH007
  • Newbie
  • Last login:September 06, 2014, 04:56:42 pm
« on: September 06, 2014, 04:57:00 pm »
Hello everyone,
I am new at this. When ground wiring a control panel, does it matter where I start and end? I understand the daisy chain concept but just wondering on tips on the order of a two player, 6 button machine
THANKS ;)
  • Last login:Today at 01:41:30 am
Re: ground wiring in control panel
« Reply #1 on: September 06, 2014, 05:38:28 pm »
Welcome aboard, RWH007.   ;D
I usually use a pattern like this.
Some people like to complete the loop back to the encoder so that even if one wire pulls out of a crimp everything still works.   ;D
When a second wire pulls out, all switches between the two pulled wires stop working.
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
« Reply #2 on: September 07, 2014, 10:34:24 am »
I agree with the "loopback" method. Start and end at the same spot.
« Reply #3 on: September 07, 2014, 11:08:12 am »
Personal preference. I don't like to do this, because the "fail safe" can hide problems. I like to know when there is a problem, track it down, and fix it.
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
« Reply #4 on: September 08, 2014, 01:36:41 am »
Common practice is one ground. This allows for easy trouble shooting.
screamingtiger
  • Last login:November 22, 2016, 11:48:41 am
« Reply #5 on: September 09, 2014, 10:03:27 am »
Just to piggy back on this question,  I have the XIN MO controller and it has places for a ground.
However two of my buttons could not reach the controller for ground, so I grounded them to the PC power supply.
This should be ok right, ground is ground?
