Author Topic: Valley Cougar dart board trips breaker after its been on for about 5 minutes.  (Read 2341 times)
KennethJ17
  • Last login:August 21, 2017, 10:22:24 pm
I got this dart board cheap because it trips the house breaker after being on for 5 minutes or so. Any ideas would be appreciated! After getting it home there is a power strip inside with several things plugged into it. Is that common? I'm fairly new to arcade style games but I thought they are all more computer like with power supplies not power strips. Thanks in advance.
« Last Edit: September 21, 2014, 04:38:24 pm by KennethJ17 »
Guero12
  • Last login:June 12, 2017, 11:18:42 am
There is usually one large power supply in a metal box.  No power strip.  The Valley Cougar power supplies I think are pretty expensive and someone probably rigged up a power supply to replace the bad one.
