Author Topic: Mala errors and issues since adding IPac ultimate (error log included)  (Read 3276 times)
liquid134
  • Last login:February 15, 2018, 07:58:20 pm
hey guys,
recently started hooking up and playing around with my IPAC ultimate, on a clean install of TinyXP (i think thats what i ended up using). Im using mala, and MAME 1.06 (my pc is a P4, with 3 gigs of ram so thats the most current i can go with mame) anyway, at first i couldnt get it to work properly (realizing today when i actually had time to sit down and work on it, i hooked up my CP wrong) so now that i have it responding to mala (somewhat) i cant get games to load, and when trying to exit mala i get an error message.
EDIT##### - also, i noticed in Task Manager (ctrl+alt+delete) that there is like more then 10 winipac.exe files loaded. is that normal?
error file below
2014/09/01  00:27:57.03  Info: ##########################################################################
2014/09/01  00:27:57.03  Info: Starting MaLa 1.7.4.0
2014/09/01  00:27:57.03  Info: LoggingLevel =  1
2014/09/01  00:27:57.03  Info: Starting usb LED/LCD device detection ...
2014/09/01  00:27:57.21  Info: Hardware: *** HidCtlDeviceChange ***
2014/09/01  00:27:57.21  Info: Hardware1: Creating object
2014/09/01  00:27:57.21  Info: Number Of Connected Hardware: 0
2014/09/01  00:27:57.21  Info: Finished usb LED/LCD device detection ...
2014/09/01  00:27:57.21  Info: Check plugin directory: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\plugins
2014/09/01  00:27:57.21  Info: Collecting event plugins (*.mplugin) in C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\plugins\
2014/09/01  00:27:57.21  Info: Check backup directory: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\backups
2014/09/01  00:27:57.21  Info: Check to see if hook dll is required
2014/09/01  00:27:57.21  Info: Win98/ME Hook dll not loaded because OS is: WinXP
2014/09/01  00:27:57.21  Info: Computer name: MAME
2014/09/01  00:27:57.25  Info: Loading config params from ini file
2014/09/01  00:27:57.32  Info: Setting params from ini file
2014/09/01  00:27:57.32  Info: Creating and loading mame cl conditions: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\mame.clc
2014/09/01  00:27:57.32  Info: Creating and loading mame info pages: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\mame.mli
2014/09/01  00:27:57.32  Info: Creating and loading other emu info pages: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\otheremu.mli
2014/09/01  00:27:57.32  Info: Creating and loading filter sets: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\mala.mlf
2014/09/01  00:27:57.32  Info: Creating and loading other Emulators: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\mala.mle
2014/09/01  00:27:57.32  Info: Collecting layout files (*.mll) in C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\
2014/09/01  00:27:57.32  Info: Creating and loading mala tree
2014/09/01  00:27:57.32  Info: Collecting game list files: (mlg) in C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\
2014/09/01  00:27:57.32  Info: Creating and loading bios
2014/09/01  00:27:57.32  Info: LoadBiosList
2014/09/01  00:27:57.32  Info: Hiding taskbar
2014/09/01  00:27:57.32  Info: Muzac: Creating audio object
2014/09/01  00:27:57.32  Info: Muzac: Loading Playlist into Memory from FILE: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\mala.pls
2014/09/01  00:27:57.32  Info: LoadPlaylist: Playlist is empty
2014/09/01  00:27:57.32  Info: Muzac: Set in Sequential
2014/09/01  00:27:57.32  Info: Muzac: Set in No Loop
2014/09/01  00:27:57.32  Info: Hardware: Loading mala lcd screens
2014/09/01  00:27:57.32  Info: Hardware: Creating and loading mame lcd screens
2014/09/01  00:27:57.32  Info: Hardware: Creating and loading jukebox lcd screens
2014/09/01  00:27:57.32  Info: Creating and loading led config and attroct mode list
2014/09/01  00:27:57.32  Info: Collecting attract mode files (*.mlc) in C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\
2014/09/01  00:27:57.32  Info: LoadGameList : Loading C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\Most Played Games.mlg
2014/09/01  00:27:57.34  Info: Current Memory used: 12,516 K
2014/09/01  00:27:57.34  Info: SetLayout: Layout Name= standard
2014/09/01  00:27:57.34  Info: SetLayout: Loading layout: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\standard.mll
2014/09/01  00:27:58.09  Info: Show Main Form
2014/09/01  00:27:58.09  Info: FormActivate:
2014/09/01  00:27:58.09  Info: Video: Start initial delay
2014/09/01  00:28:00.15  Info: Saving game list: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\Most Played Games.mlg
2014/09/01  00:28:00.15  Info: Starte: Current Memory used: 17,036 K
2014/09/01  00:28:00.15  Info: Starte: Cancel any Display & Video Delay due to game start
2014/09/01  00:28:00.15  Info: Programming Encoder: C:\Program Files\WinIPAC V2\WinIPAC.exe C:\Program Files\WinIPAC V2\Defaults\Default2P.ipc
2014/09/01  00:28:02.15  Info: Saving game list: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\Most Played Games.mlg
2014/09/01  00:28:02.15  Info: Starte: Current Memory used: 17,100 K
2014/09/01  00:28:02.15  Info: Starte: Cancel any Display & Video Delay due to game start
2014/09/01  00:28:02.15  Info: Programming Encoder: C:\Program Files\WinIPAC V2\WinIPAC.exe C:\Program Files\WinIPAC V2\Defaults\Default2P.ipc
2014/09/01  00:28:10.87  Info: Saving game list: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\Most Played Games.mlg
2014/09/01  00:28:10.87  Info: Starte: Current Memory used: 20,156 K
2014/09/01  00:28:10.87  Info: Starte: Cancel any Display & Video Delay due to game start
2014/09/01  00:28:10.87  Info: Programming Encoder: C:\Program Files\WinIPAC V2\WinIPAC.exe C:\Program Files\WinIPAC V2\Defaults\Default2P.ipc
2014/09/01  00:28:13.87  Info: Saving game list: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\Most Played Games.mlg
2014/09/01  00:28:13.87  Info: Starte: Current Memory used: 20,156 K
2014/09/01  00:28:13.87  Info: Starte: Cancel any Display & Video Delay due to game start
2014/09/01  00:28:13.87  Info: Programming Encoder: C:\Program Files\WinIPAC V2\WinIPAC.exe C:\Program Files\WinIPAC V2\Defaults\Default2P.ipc
2014/09/01  00:28:15.87  Info: Saving game list: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\Most Played Games.mlg
2014/09/01  00:28:15.87  Info: Starte: Current Memory used: 20,156 K
2014/09/01  00:28:15.87  Info: Starte: Cancel any Display & Video Delay due to game start
2014/09/01  00:28:15.87  Info: Programming Encoder: C:\Program Files\WinIPAC V2\WinIPAC.exe C:\Program Files\WinIPAC V2\Defaults\Default2P.ipc
2014/09/01  00:28:16.87  Info: Saving game list: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\Most Played Games.mlg
2014/09/01  00:28:16.87  Info: Starte: Current Memory used: 20,156 K
2014/09/01  00:28:16.87  Info: Starte: Cancel any Display & Video Delay due to game start
2014/09/01  00:28:16.87  Info: Programming Encoder: C:\Program Files\WinIPAC V2\WinIPAC.exe C:\Program Files\WinIPAC V2\Defaults\Default2P.ipc
2014/09/01  00:28:18.87  Info: Saving game list: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\Most Played Games.mlg
2014/09/01  00:28:18.87  Info: Starte: Current Memory used: 20,156 K
2014/09/01  00:28:18.87  Info: Starte: Cancel any Display & Video Delay due to game start
2014/09/01  00:28:18.87  Info: Programming Encoder: C:\Program Files\WinIPAC V2\WinIPAC.exe C:\Program Files\WinIPAC V2\Defaults\Default2P.ipc
2014/09/01  00:28:22.82  Info: popMainPopup:
2014/09/01  00:28:22.82  Info: BuildGameListMenu: Adding New Menu 1 All Games
2014/09/01  00:28:22.82  Info: BuildGameListMenu: Adding New Menu 2 Most Played Games
2014/09/01  00:28:22.82  Info: BuildGameListMenu: Adding New Menu 3 MYMAME
2014/09/01  00:28:22.82  Info: BuildGameListMenu: Adding New Menu 4 Working
2014/09/01  00:28:26.17  Info: Saving game list: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\Most Played Games.mlg
2014/09/01  00:28:26.17  Info: Starte: Current Memory used: 20,204 K
2014/09/01  00:28:26.17  Info: Starte: Cancel any Display & Video Delay due to game start
2014/09/01  00:28:26.17  Info: Programming Encoder: C:\Program Files\WinIPAC V2\WinIPAC.exe C:\Program Files\WinIPAC V2\Defaults\Default2P.ipc
2014/09/01  00:28:26.17  Info: LoadGameList : Loading C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\MYMAME.mlg
2014/09/01  00:28:26.17  Info: Current Memory used: 20,204 K
2014/09/01  00:28:31.20  Info: Saving game list: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\MYMAME.mlg
2014/09/01  00:28:31.20  Info: Starte: Current Memory used: 20,204 K
2014/09/01  00:28:31.20  Info: Starte: Cancel any Display & Video Delay due to game start
2014/09/01  00:28:31.20  Info: Programming Encoder: C:\Program Files\WinIPAC V2\WinIPAC.exe C:\Program Files\WinIPAC V2\Defaults\Default2P.ipc
2014/09/01  00:28:38.25  Info: Saving game list: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\MYMAME.mlg
2014/09/01  00:28:38.25  Info: Starte: Current Memory used: 20,216 K
2014/09/01  00:28:38.25  Info: Starte: Cancel any Display & Video Delay due to game start
2014/09/01  00:28:38.25  Info: Programming Encoder: C:\Program Files\WinIPAC V2\WinIPAC.exe C:\Program Files\WinIPAC V2\Defaults\Default2P.ipc
2014/09/01  00:28:41.25  Info: popMainPopup:
2014/09/01  00:28:41.25  Info: BuildGameListMenu: Adding New Menu 1 All Games
2014/09/01  00:28:41.25  Info: BuildGameListMenu: Adding New Menu 2 Most Played Games
2014/09/01  00:28:41.25  Info: BuildGameListMenu: Adding New Menu 3 MYMAME
2014/09/01  00:28:41.25  Info: BuildGameListMenu: Adding New Menu 4 Working
2014/09/01  00:28:45.54  Info: Saving game list: C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\MYMAME.mlg
2014/09/01  00:28:45.54  Info: Starte: Current Memory used: 20,224 K
2014/09/01  00:28:45.54  Info: Starte: Cancel any Display & Video Delay due to game start
2014/09/01  00:28:45.54  Info: Programming Encoder: C:\Program Files\WinIPAC V2\WinIPAC.exe C:\Program Files\WinIPAC V2\Defaults\Default2P.ipc
2014/09/01  00:28:45.54  Info: popMainPopup:
2014/09/01  00:28:45.54  Info: BuildGameListMenu: Adding New Menu 1 All Games
2014/09/01  00:28:45.54  Info: BuildGameListMenu: Adding New Menu 2 Most Played Games
2014/09/01  00:28:45.54  Info: BuildGameListMenu: Adding New Menu 3 MYMAME
2014/09/01  00:28:45.54  Info: BuildGameListMenu: Adding New Menu 4 Working
2014/09/01  00:28:46.39  Info: FormClose
2014/09/01  00:28:46.39  Info: FormClose: There are no active plugins to close.
2014/09/01  00:28:46.39  Info: FormClose: Video1 Window now Closed
2014/09/01  00:28:46.39  Info: FormClose: Video2 Window now Closed
2014/09/01  00:28:46.39  Info: FormClose: Muazc Not Playing
2014/09/01  00:28:46.39  Info: Writing params to ini file
2014/09/01  00:28:46.48  Info: Muzac: Saving Playlist from Memory to FILE : C:\Documents and Settings\Administrator\My Documents\MaLa174\MaLa174\mala.pls
2014/09/01  00:28:46.48  Info: Muzac: Saving Playlist. Number of Songs to save= 0
2014/09/01  00:28:46.48  Info: Screensaver: ScreenSaver Form Destroyed
2014/09/01  00:28:46.48  Info: FormClose: ShowTaskbar
2014/09/01  00:28:46.48  Info: Showing taskbar
2014/09/01  00:28:46.50  Info: Closing MaLa v  [1.7.4.0]
2014/09/01  00:28:46.50  Info: **************************************************************************
2014/09/01  00:28:54.50  Info: popMainPopup:
2014/09/01  00:28:55.54  Info: FormClose
2014/09/01  00:28:55.54  Info: FormClose: There are no active plugins to close.
2014/09/01  00:28:55.54  Error: Exception Message: Access violation at address 006D339A in module 'MaLa.exe'. Read of address 00000000, Object Function: FormClose, Exception Class: EAccessViolation, Object Class: TPopupList
2014/09/01  00:28:56.84  Info: Showing taskbar
2014/09/01  00:28:56.84  Error: AppException: Terminating MaLa
« Last Edit: September 01, 2014, 05:14:26 pm by liquid134 »
liquid134
Re: Mala errors and issues since adding IPac ultimate (error log included)
« Reply #1 on: September 01, 2014, 11:45:48 pm »
i got games to load, still have the exit issue. and im still concerned about how many winipac.exe are loaded when i run mala/mame
